No Cruise, Turn Signal, or Hazards On My Cascadia
Discussion in 'Experienced Truckers' Advice' started by jldilley, Aug 21, 2022.
  1. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Hey, everyone. All of a sudden my 2012 Cascadia is having electrical issues.
    1. My turn signals are not working, but my headlights and daytime running lights work fine.
    2. My high beams will not work when I engage them.
    3. My cruise control is not working. In fact, none of the controls mounted on the steering wheel are working.
    4. My hazards are not working. The led light on my hazard light button is flashing rapidly.
    I’m going to guess a relay, fuse, or several of either have burned out. The problem seems to be centralized to controls on my steering wheel, except for the hazards, but the problem with the hazards is probably related to the turn signals not working. Anyone experienced with this issue? I greatly appreciate your help.
    ~Josh
  3. Animosus
    Animosus Heavy Load Member
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    There are almost certainly fault codes in the MSF or Sam_Cab related to those issues since everything is computer controlled. Just based on the large number of failures I'd look at a faulty sam_cab, probably from a windshield leak.
    jldilley Thanks this.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Did you spill coffee or a drink on the steering wheel at any time?
    tscottme and jldilley Thank this.
  5. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    I haven’t, but my windshield has leaked periodically for the last month or so.
    tscottme and baha Thank this.
  6. baha
    4,137
    2,835
    Jul 25, 2013
    ga
    Well just start talking apart all the plug in connector and be looking for green corr. on the pins inside of them, just take the lower cover off the steering column and start there, if you decide pull the wheel off look at the rings that the contact arms ride on to be sure it's clean?
  7. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Check for blown fuses also.
    Buy a test light and probe the fuse ends. If one side lights up but the other don't. It's blown.
    I used to drive a truck with same trailer. Sometimes when it rained. The right turn signal quit. It also meant no brake lights. The brake light fuse would pop.
  8. Animosus
    708
    2,774
    Dec 7, 2015
    SE Wyoming
    Can almost guarantee it is a faulty sam_cab now. And you probably need the Drip Shield Enhancement. Service Bulletin 54-312
  9. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    I forgot to add that the left-most check engine light is on and that my city horn functions normally.
  10. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    The hazard light button’s LED continues to blink when I shut the engine off.
  11. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    This is getting very weird. Now my truck and trailer lights will not turn off.
