Nexiq data link 2 not detected on laptop
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kentuckynet, Nov 6, 2024.
  1. kentuckynet
    kentuckynet Bobtail Member
    8
    Nov 3, 2012
    hello, i installed the drivers, plugged in the usb to the laptop and its not detected.
    I went to device manager nothing is added or removed when i plug it in.
    im using windows 10 64 bit and tried it on a windows 7 64 bit, same results.
    I used the device tester and its not detected.
    Is it suppose to be plugged into the truck maybe to provide power to the nexiq unit?
    i purchased the unit new and when i first used it i followed the driections and went to the nexiq website downlaoded the drivers and dont remeber having any problems.,
    that laptop is no longer available.
    please help
    mack
    The_vett Thanks this.
  3. Iamoverit
    Iamoverit Road Train Member
    1,539
    3,330
    Oct 31, 2023
    Check the fuse for your data port.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Do you have the correct Nexiq selected in the application? It should detect the device when not connected to the truck after everything functions. You will need to hook up to a truck for device tester to work.
    How long ago did you purchase? Nexiq 2 pretty sure is no longer available. Tried to order one a couple months ago and was told new replacements were no longer available.
    Reach out to Nexiq support. They are usually helpful.
