Nexas diagnostic tool force regen
Discussion in 'International Forum' started by midnite48161, Aug 20, 2019.
  1. midnite48161
    midnite48161 Bobtail Member
    10
    Aug 13, 2019
    I love this handheld diagnostic tool the nexas nl102p . It already save me money. Only problem I'm having is it won't Force Regen have anybody else got it to work that may have it. I have the maxxforce 13
  3. AModelCat
    154,278
    Does the engine actually require a forced regen?
    mhyn Thanks this.
  4. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
  5. midnite48161
    10
    Aug 13, 2019
    mine did yesterday when I had to take it to a dealership to get it done but there was a problem with my truck but still it would have saved me money
  6. mhyn
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    midnite do you know what is * DPF Zones *?
  7. midnite48161
    10
    Aug 13, 2019
    Yes mine went straight to red light stop engine. Once I got into the dealership they did a regen on it and I was good. Since my Fpcv was messed up it was causing my problems
  8. Lockport
    Lockport Light Load Member
    170
    112
    Mar 26, 2011
    Lockport, MB, CAN
    Apparently you must be at a significant operating temp or it will show that error "FUNCTION NOT SUPPORTED". I've seen it, too but I've heard various claims of engine temps between 150° to as high as 200° and it will initiate a Regen. I have used this tool many times to clear active codes and power derates and will swear by it to get you home. I've even had it clear a STOP engine and shutdown. But if you've multiple repeat codes and STOP engine 5mph derates, say a failed One-Box, it cannot clear that. Legally that is a fatal Emissions system failure in accordance with the EPA regulations and I nothing can clear that but the repair.
  9. sirrepairsalot
    sirrepairsalot Light Load Member
    66
    28
    Aug 9, 2018
    Canada
    That Detroit problematic whistling, idle hunting issue?
