New truck with Allison 4000 transmission problems.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by NFDDJS, Sep 20, 2015.
  1. NFDDJS
    NFDDJS Light Load Member
    267
    37
    Jul 8, 2012
    New Hampshire
    Truck has been shifting hard and almost like it was hanging up and slipping. Took it to the dealer 4 times they "reprogrammed it" and nothing changed. Friday the truck got stuck in 5 gear. Had it towed in and now they are saying the filter is plugged and also the fluid coloring is "off" and looks like it is almost fluorescent in color.
    Anyone have any ideas?
    They sent the fluid out to get tested.
    Truck only has 10,000 miles on it.
  3. CJndaTruck
    CJndaTruck Road Train Member
    3,348
    3,364
    Nov 21, 2014
    Knoxville, TN (area)
    Fluorescent as in coolant? That would be a problem.
  4. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    Looks like it could be.
  5. AModelCat
    154,281
    Sometimes they'll throw UV dye into oil to help ID a leak. GM did that to my pickup when it was new due to a leak. Flash forward to 80,000km and the local transmission shop calls me up to ask if I ever had dye put into the transmission because the old fluid was fluorescent orange when he did the transmission filter change.
  6. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    It does look orange/red in color. We have other trucks with Allison and no problems at all but this one from day one has not seemed right
  7. AModelCat
    154,281
    If the filter was plugged, she might be toasted. A relative had a pickup with a 4L80E auto and it started acting up after about 20,000 km. Dealer replaced the speed sensor a bunch of times over the next 5,000 before finally pulling the tranny. Found everything inside was melted. No idea how the truck even drove.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Spin on Filter should have been serviced very early. If it's plugged that's VERY bad on a Allison!
    Damage has been done.
  9. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    Someone put the wrong fluid in it? These things don't use ATF. We've got a few oilfield trucks with the 4500 Allisons, and they're relatively bulletproof as long as they're serviced at the appropriate intervals (50K miles for us, severe duty, 24/7 operation).
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    Stucking ih 5th gear usually not related with incominated fluid/
    it is solenoid valve problem
    Use Allison DOC software to actuate valves one by one and check bad valve by sound.
    Check also VSS and TPS data!
  11. NFDDJS
    267
    37
    Jul 8, 2012
    New Hampshire
    Come to find out the cooler for the transmission broke and filled the transmission with coolant.
    They shipped a new trans and I should have it back up and running this week.
