New to tanker, overweight tandem axles
Discussion in 'Experienced Truckers' Advice' started by Floridaman72, Jul 2, 2022.
  1. Floridaman72
    Floridaman72 Bobtail Member
    21
    32
    May 24, 2022
    Florida
    I've been doing dry van for 3 years but this is my first time hailing tanker.
    So I don't have sliding tandems but my tandem (trailer) axle is over weight. I've tried sliding my fifth wheel to practically zero effect in either direction.
    Is there anything I can do besides go back to the shipper?
    Weights...
    Steer: 13720
    Drive: 30520
    Tandem: 35280
    Gross: 79520
    Boondock Thanks this.
  3. Floridaman72
    21
    32
    May 24, 2022
    Florida
    Steers are also overweight with current fifth wheel configuration
  4. REO6205
    REO6205 Road Train Member
    13,172
    60,482
    Feb 15, 2014
    California.
    If it's a single compartment trailer, you're screwed. You'll have to take it back to the shipper.
    jamespmack, tscottme and Boondock Thank this.
  5. Chinatown
    Chinatown Road Train Member
    73,230
    164,412
    Aug 28, 2011
    Henderson, NV & Orient
    I've been in that situation. The way I got away with it is to tap the brakes hard enough to get the liquid surging pretty hard just before pulling on the scales. This way, when you pull on the scales, usually the scale master will give you the green light; otherwise you might sit there for 30 minutes waiting for it to calm down. You're under gross, so should be ok.
    Magoo1968, mustang190, armo and 8 others Thank this.
  6. LTL Bull
    LTL Bull Road Train Member
    1,561
    6,561
    Mar 12, 2020
    Did you let it settle before weight was checked? If it was moving the scale may be inaccurate.
    tscottme, Boondock and Chinatown Thank this.
  7. Floridaman72
    21
    32
    May 24, 2022
    Florida
    I waited about 2 minutes
  8. Floridaman72
    21
    32
    May 24, 2022
    Florida
    I'm hauling from ohio across 80 to iowa.
    I heard rumor that weigh stations only care about gross weight for tankers but I'm not risking it. I'm hauling a smooth bore single compartment food grade trailer.
    I may just go back and have some taken out if dispatch gives the green light.
  9. YumDinger
    YumDinger Light Load Member
    79
    154
    May 5, 2022
    Run it....there is nothing wrong.
  10. Chinatown
    73,230
    164,412
    Aug 28, 2011
    I ran 48 states and Canada with loads like that and never had a problem at the scales.
  11. Broke_and_Hungry
    Broke_and_Hungry Light Load Member
    222
    501
    Feb 26, 2008
    Not enough information to make that determination. If the GVWR on the steer is 14k or greater, and the tires are 7k or greater, the steer is not over.
    Any axle can weigh 20k as long as the GVWR and the tires on that axle can accommodate the weight.
