New Radiator
Discussion in 'Ask An Owner Operator' started by Beaver9, Oct 22, 2021.
  1. Beaver9
    Beaver9 Heavy Load Member
    966
    1,183
    Jun 15, 2020
    Already spent 5K in repairs this month (Kennworth T660--year 2010). Now, I need a new radiator. FXXK. How much does it usually cost to replace it? I will get most likely after market one.
    I already spent additional 10K+ in July/August/September. Soon I will get to 20K in repairs in such a short time.
    How much time does it take to replace a radiator? And what's the usual cost?
    Rideandrepair Thanks this.
  3. blairandgretchen
    13,210
    70,197
    Dec 9, 2011
    South west Missouri
    At dealer or independent?
  4. Beaver9
    966
    1,183
    Jun 15, 2020
  5. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Find a clean container you can drain 10-13 gallons into. Remove the old one.
    Make a burping cap. Replace with a new radiator, put on the burping cap. Add fuild.
    I have no idea how long it takes. But I would guess less than 4 hours. Assuming your draining into a 5 gallon bucket. And have to stop the drain to swap buckets. And using a old glass picture to replace the fluid. The burping cap is key thou.
  6. blairandgretchen
    13,210
    70,197
    Dec 9, 2011
    South west Missouri
    Cost of radiator, 5 hours labor, coolant, hoses and clamps. Often easier with hood removed.
    Cost of business.
    I had mine recored when the front end was apart for an unrelated issue.
    Learn the ‘sensuous’ maintenance - like “Since you is “ in there.
  7. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    Radiator core or complete assembly.
    I've had my radiator replaced in a day. Had one re-cored took 3 days. Independent shop.
  8. Rideandrepair
    17,197
    55,775
    Aug 8, 2015
    All of a sudden you need a radiator? Is it leaking? Running hot? I’d guess about $1700. Start by calling the Dealer. Then check Americancoolingsoulutions.com. Other aftermarkets are out there. If it’s not leaking, maybe a thermostat, fan, waterpump? Maybe needs a good flushing, or fins are blocked by debris in them, or debris in cac fins, a/c condensor fins? Blocking airflow.
  9. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    You're looking at roughly 3500 for everything installed. Lots of factors can affect the end cost though.
    Beaver9 and feldsforever Thank this.
  10. rollin coal
    rollin coal Road Train Member
    13,077
    25,826
    Mar 29, 2008
    TN
    I thibk I paid about $1200 for an Active brand 4 rows replacement radiator for my T600 about 5 years ago. Of course now with Joe "I did that" everywhere it probably costs about 30% more these days (thanks Joe!)
    I would suggest dunking it in a water tank to check for leaks before installing. My first one leaked and had to be swapped for another... I dunno what it cost to install. It was put in by a CAT house during an inframe I had them swap out the old one.
  11. Siinman
    Siinman Road Train Member
    5,156
    12,909
    Mar 5, 2017
    Kansas City, MO.
    On my 2014 Volvo 670 it cost
    2398.74 in 2019 from Volvo dealer. It took them one day in shop to finish.
