New motor for a cabover
Discussion in 'Trucks [ Eighteen Wheelers ]' started by czego82, Dec 13, 2016.
  1. czego82
    czego82 Light Load Member
    160
    44
    Nov 15, 2014
    anyone knows or seen what is the biggest motor that can fit into Freightliner FLB cabover? Currently has little C-10 and I want to see if N-14 would fit or DD60? It's a project truck....
  3. Roger McG
    Roger McG Light Load Member
    165
    198
    Oct 22, 2016
    western mass
    I don't see why you couldn't use 1 of the larger bore engines with the proper engine mounts,cooling systems,etc. Anything is possible it's just nuts and bolts
    Big_D409 and AModelCat Thank this.
  4. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    And money, lots and lots of money.
    Big_D409 and BoxCarKidd Thank this.
  5. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    I'm sure that those cabovers came out of the freightliner factory with n 14's or detroit series 60's maybe even 3406e or c-15 cats.I'm sure you could buy a complete parts truck for the same money as a complete engine then still have all the small nickel and dime parts that you need on those swap projects
    BoxCarKidd Thanks this.
  6. Ristow
    Ristow Road Train Member
    1,314
    1,996
    Jun 28, 2014
    Fema Region 5
    They all fit. My FLA (same can as yours) has 60 series. Flb at the shop has a 3406b in it.
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    There is a post on here somewhere about one with a K series Cummings. Saw an Astro with V12 and Ozdriver has a 3408 in a KW. Don't see why those won't fit in yours as well.
    Surely not the best chose doing those swaps but you asked what is the largest that will fit. There is no other sound like a buzzing dozen.
    Cabover Mike and Roger McG Thank this.
  8. AModelCat
    154,488
    Or shortages of oil stains under it lol.
    noluck and Roger McG Thank this.
  9. Roger McG
    165
    198
    Oct 22, 2016
    western mass
    If there isn't a puddle oil under those 2 stroke detroits,there probably ain't no oil in it haha
    207nomad Thanks this.
  10. BoxCarKidd
    4,418
    6,432
    Aug 26, 2014
    For a buzzing dozen with the right running gear that was external lubrication for the slip stream before the jump to light speed. An old man had a butterfly hood 4000 White, extended frame to make room for it plus mount the bumper and radiator forward. Hood looked like two cut and welded together with a torch and coat hanger with special paint brush effects. Everyone laughed at it. He said: "When the fenders get to going this away and the head lights get to going that away, with hand motions, all it needs is more road." Probably not much out there today that could run with it or use that much fuel. LOL
    Dino soar, AModelCat and Roger McG Thank this.
  11. Diesel Dave
    8,526
    23,505
    Jan 20, 2010
    Hesperia, Ca.
    Ahhhh..... the Cummins K series, those where engines back in the day. You could sometimes spot them in certain trucks, Freightliner had the bigger grill.
    Roger McG Thanks this.
