New local driver question about airline gladhand
Discussion in 'Mack Forum' started by mikecpjr12, Aug 25, 2013.
  1. mikecpjr12
    mikecpjr12 Bobtail Member
    11
    Aug 25, 2013
    charlotte nc
    Im a local driver out of Charlotte NC with a company based out of Florida and the nearest terminal in Atlanta. My question is my glad hand on my tractor continues to fall off the airline.
    After this happens each time a local shop mechanic takes a razor blade and cuts a little of the line off and sticks glad hand back on. Is there a permanent fix for this.
    mje Thanks this.
  3. Charli Girl
    Charli Girl Road Train Member
    1,371
    668
    Mar 23, 2013
    Houston,Tx
    Walk outside go into your side box,grab a hammer and get on cat walk bend down and WHACK the metal part that connects the glad hand. LOL It tightens it up. I have to do it everyday with a different trailer!! I have a small crowbar and I put it under the glad hand to line em up correctly then I tap the bottom of the glad hand to get them good and tight.
    :biggrin_25514:
    mje Thanks this.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    Tell your shop to quit being so cheap and put new gland hands on the tractor.There's your permanent fix.
    Skunk_Truck_2590, mje and paul_4lp Thank this.
  5. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I was going to say that but im thinking its something else if the shop keeps using a razor blade on it.
    mje Thanks this.
  6. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    i think he means the hand falls off the air hose. If thats the case, get a new line with hand already attached or use a hose clamp on real tight.
    mje Thanks this.
  7. richardj87
    richardj87 Bobtail Member
    31
    9
    Aug 24, 2013
    dsm Iowa
    did i read that correct? the glad hand is falling off the airline? sounds like maybe the plastic synflex airline with a quick connect fitting on the glad hand maybe? if thats the case have them use a compression fitting. It sounds pretty dangerous to be not fixing it correctly
    mje Thanks this.
  8. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    That is how I read it also. Need to install new lines if this is happening. A set of red and blue coil lines are not that expensive. Maybe 50.00-60.00 range for the set and gland hands are in the 5-10 a piece range. So for 70.00 no more problems.
    If the glad hands are just unhooking from the trailer and not the air line blowing off of them then just install new glad hands.
  9. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    in conclusion, no matter what part is breaking, replace it.
  10. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    I intertwine the other cables on top of the lose one to weigh it down.
  11. pattyj
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I talked to a GA driver name bubba j and he says duct tape it,lol.He thinks duct tape is the answer to everything.My hillbilly mobile proves that.
