new inframe. white smoke from exhaust, ideas?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 410Truckin, Jun 27, 2020.
  1. 410Truckin
    410Truckin Bobtail Member
    17
    5
    Apr 28, 2020
    Westminster, Maryland
    Just got an inframe done 5k miles ago. I'm noticing white smoke when I idle. Wasnt losing coolant as far as I could tell up until today I had to put a gallon in. Where could this be coming from? (New charge air cooler, borg Warner turbo,) running out of possibilities.
  3. bad-luck
    bad-luck Road Train Member
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Are you sure that the exhaust is from coolant? Does it smell like coolant? I know you said that you put in a gallon, but some trucks will spit coolant out of the overflow until they find there smooth spot. Are you sure it's not an injector? Also side you change the air compressor?
  4. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,738
    Mar 19, 2018
    Nashville
    First and easiest thing to do is pressure check the cooling system.
  5. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Fuel could be contaminated.
    I had a motor overhauled. The shop to save me money, didn't change the fuel filter, because a week earlier I had a oil and filters changed in there shop.
    When I left truck was smoking a little white. Mechanic explained it as usual and it will go away.
    100 miles later truck shut down. Fuel filter was full of water.
    bad-luck and Coffey Thank this.
  6. 410Truckin
    17
    5
    Apr 28, 2020
    I havent changed the compressor at all. I did have a fault code for the engine speed / crank shaft sensor. Which I changed. Could the timing be off after changing it?
    Coffey Thanks this.
  7. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    If the timing was off i would think it would throw a code? What motor?
    Coffey Thanks this.
  8. 410Truckin
    17
    5
    Apr 28, 2020
    Isx. I forgot to list that. My only engine code is "731" the engine speed sensor/ crankshaft sensor which I switched out but still getting the code. Both sensors are good.
  9. Rideandrepair
    17,209
    55,822
    Aug 8, 2015
    Coolant could have just worked all the air pockets out, may not be losing any. Sure it’s not bluish smoke from oil? Time for an oil change anyways, have the coolant pressure tested. Make sure it will hold 10 or 15 lbs. Make sure it’s not building excess pressure while it’s running.
    lwlevens Thanks this.
  10. bad-luck
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    I dont think so. There are only a few places that coolant goes if you are loosing it. Out the stack, in the oil, or on the ground
  11. bad-luck
    3,247
    5,945
    Nov 16, 2013
    Baltimore, Maryland
    Don't think it was air pockets, because he has 5k on the motor after an inframe
    Rideandrepair Thanks this.
