New Hendrickson trailer suspension?
Discussion in 'Ask An Owner Operator' started by Midwest Trucker, Feb 26, 2019.
  1. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    I’m spec’ing a new Wabash reefer and the salesman said the stock they have on order comes with the new Hendrickson suspension. Didn’t get a model name yet but supposedly it doesn’t have any shocks?
    I’m going to do some research but anybody have any experience with this? No shocks? Sounds crazy!
  3. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Shocks probably inside of the air bags
    KB3MMX Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    The air bags have two compartments with a small opening between them so they soften the ride on the way down and on the way up.
    I only learned about them two months after I had just changed out mine, otherwise I would have put them on.
    KB3MMX and Midwest Trucker Thank this.
  5. Truck Whisperer
    Truck Whisperer Bobtail Member
    7
    6
    Feb 27, 2019
    Bakersfield California
    The New Hendrickson Suspension is more streamlined and simple. The airbag is an air spring. The bag has a built in shock to slow the movement down. The bags are obviously more expensive too. They ride nice and perform well. Hopefully it comes with the sure loc feature to steady your trailer at the dock with brakes applied. Your rubber bumper pads will last longer too. Since you’re getting a new trailer make sure the first thing you do is go get it aligned at a reputable shop. 90% of our new trailers needed the alignment even though they appear to pull straight. Good luck!
    PE_T and Midwest Trucker Thank this.
  6. Midwest Trucker
    5,871
    21,125
    Aug 31, 2018
    Thanks for the great info and insight!
    Yes, has the surelok and 10-4 on the alignment.
  7. PE_T
    PE_T Road Train Member
    My trailer has the new Hendrickson suspension with no visible shocks. I think it’s been out for about 2 years. It also comes with four chains, two on each axle to apparently keep the tandem and trailer together on very bumpy roads.
    Midwest Trucker Thanks this.
  8. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Can someone retrofit the new style airbag to an older suspension?
    Do they make it for spread axle flatbeds?
  9. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Yes you can use them on an existing trailer.
    But you do have to remove the shocks and install a length of chain in its place to prevent overextending the air bag.
    PE_T Thanks this.
  10. RedForeman
    RedForeman Momentum Conservationist
    4,875
    22,138
    Jan 30, 2011
    If they already have them on order, the salesman should be able to email you a sample build sheet with the Hendrickson part number printed right on it.
  11. Ccbrown8858
    Ccbrown8858 Bobtail Member
    10
    9
    Mar 18, 2019
    The slider suspension is called Hendrickson ULTRAA-K.
    Hendrickson - ULTRAA-K - Revolutionary Air Slider Suspension System
    The air spring piston (the carbon fiber part) is capped on the bottom and has stratigically placed and sized holes to vent the air spring pressure between the bellows (rubber part) and the piston. The suspension was initially launched in 2014. The air springs are a little more expensive, but if anything happened to one on the road and you couldn’t find a direct replacement immediately, you can use a standard VANTRAAX air spring to “limp” it home until you get the right bag back on it.
    Another nice feature on that suspension is the pivoting mud flap brackets.
    Midwest Trucker and PE_T Thank this.
