New fault codes ...air/fuel related Fmi 16 5357 Fmi 20 3563 Fmi 1 2631 Fmi 13 108
Discussion in 'Freightliner Forum' started by Emil Baran, Jun 1, 2017.
  1. Emil Baran
    Emil Baran Light Load Member
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Truck sat for 2 weeks, came back from vacation and 1st fault code that popped was from inlet manifold sensor then other followed within 50 miles. Any suggestions , location of sensor. DD15 in 2012 Cascadia
    Fmi 16 5357
    Fmi 20 3563
    Fmi 1 2631
    Fmi 13 108
  3. RocketyMan
    RocketyMan Medium Load Member
    549
    336
    Jun 5, 2015
    It really helps when you put fault codes in the order of: SA/SPN/FMI
    So like this:
    1/5357/16--Total injected fuel mass too high
    1/3563/20--Ambient and Inlet Manifold Pressure Difference (Low Box)
    1/2631/1--Unexceptable long time in smoke mode
    Truck sat for a couple weeks...I wonder if you have sticky/leaky injectors!
    Emil Baran Thanks this.
  4. RocketyMan
    549
    336
    Jun 5, 2015
    Well I guess it is from a faulty inlet manifold sensor, aka delta P sensor. Probably full of crud. BTW...my cut and copy isn't working from PSL. Ugh...
    SPN 5357/FMI 16
    Description Fuel Quantity High Detected
    Monitored Parameter Injector Quantity
    Typical Enabling Conditions Steady State Drive & No Regen
    Monitor Sequence None
    Execution Frequency Continuous when enabling conditions met
    Typical Duration 2 Minutes
    Dash Lamps MIL, CEL
    Engine Reaction Derate 25%
    Verification Steady Engine RPM 1400 - 1500 (2 minute)
    1. Monitor the intake manifold temperature; is the intake manifold temperature reading greater than 65°C (150°F)?
    1. Compare intake manifold pressure to atmospheric (Baro) pressure. Is the intake manifold pressure within 0.4 psi of Baro pressure?
    1. Remove the EGR delta P sensor from the mounting pad; leave electrical harness connected. Refer to section "Removal of the Delta P Sensor" .
    2. Is the EGR delta P voltage between 0.55 and 0.83 volts?
      1. Leak check the Charge Air Cooler (CAC); refer to OEM literature for procedure.
  5. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Hmm never had any problems with injectors before, i am using Lucavs or howes . I just bought the sensor and will replace it 2morrow to see if it helps the issue
  6. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Is that the one on the driver side covered by pueve of metal ? I thought delta P is somehwere closer to a firewall.
  7. RocketyMan
    549
    336
    Jun 5, 2015
    No no no...it's located on the cross pipe in front of the engine. It gets a lot of crud because the exhaust gasses get cooled by the EGR and then you get a deposition of carbon that winds up on all the surfaces. You can use carburetor cleaner to loosen and dissolve the crud a little.
    ALSO! The pigtail on the delta P sensor is VERY VERY finiky. Pay close attention if there is any pin fretting. You'll notice how the pigtail hangs out right there which causes the whole thing to vibrate excessively and move whichever way. This can, in addition, lead to poor connection to the sensor itself because the female pins get worn out very easy--even tho the sensor itself might be good!
  8. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    I replaced intakw manifold sensor and Delta P and the only cose left is 5357/16--Total injected fuel mass too high.
    Truck seems to be runninf fine , pulling 44k as I write this. Could it be a matter of only clearing the code ?
  9. RocketyMan
    549
    336
    Jun 5, 2015
    Did the code become inactive? It might need a certain deactivation time in order to self heal--otherwise yes, it might need to be cleared.
    If it is still active, you might need to check several things still such as:
    EGR hot pipe clogged (you might need to take off this pipe and see if there is a huge amount of crud buildup)
    Check the CAC for leaks
    Is your intake manifold temp sensor still reading really high?
    Whats the Delta P sensor voltage readings?
  10. Emil Baran
    57
    4
    Mar 9, 2016
    Cleveland,Ohio
    Update : after 550 mile drive and multiple egine starts MIL light went off and no codes are showing.
    Thanks for all the help
  11. RocketyMan
    549
    336
    Jun 5, 2015
    Awesome! Right on!
