I was curious and couldnt pull up anything with the way i was searching but if you say had a 1999 or older truck so you wouldn't have to run elogs now but even just a non-emissions trucks, and wanted a newer engine (emissions engines) do you have to use all the emissions stuff. Is it like in cars you have to just meet the emissions of your car year or does it go by like engine year?
You may ask why would a person want a newer engine. They should technically be more effecient with the newer technology minus the emissions stuff. So in theory it should get better mpg. And if it would be legal to remove the emission stuff, shouldn't it run better then a non emissions motor.
I apologize in advance i know not any mods about emissions delete but trying to see the if this would be legal.
New engine in older truck
Discussion in 'Trucks [ Eighteen Wheelers ]' started by djmurria, Feb 7, 2017.
You can find places that have a crate engine with all new parts but all i can think of is put it in reman engines.
Why put a emissions motor in it. Do like the other poster stated. Crate reman for that year trk.
Ruthless Thanks this. -
The engine year is what determines the emissions. If you put one in that needed EGR, it must have EGR. If it had DPF, then you need DPF.
So to avoid the ELD mandate, which probably is on the chopping block anyway, you get a 1999 or older, then install an engine that requires emission controls that aren't more efficient than what you would have in that truck originally? -
You must have posted after i started writing so i had to edit my post. Ok thanks i was just curious how that works and thought it would be like cars. Oh if they are pretty much the same in effeciency not really worth it then. I thought it would kind of be like sbc to lsx gas engines, newer tech better mpg more power but i guess with diesels not the same.
BoxCarKidd Thanks this.
