Hi guys, I am new to this site, and i am not sure where I should be posting this question. I just got moved into a 2012 KW c500 tri drive with a Cummins isx15, it has a 18 speed with a 4 speed aux transmission .I have not seen any torque charts for this engine and i am new to Cummins [off of a truck with a Detroit series 60].The engine pulls good down low and i am wondering if I am doing damage to my tranny by pulling down to 1150 rpm in the hills, keep in mind that i am pulling a 24 low with a booster so I am usually at the 90,000-100,000 kg weight range. Also I don't care about fuel economy, so what is the best rpm for pulling heavy loads with this engine? Thanks for any input that I get.
New Cummins ISX15 550 HP.
Discussion in 'Canadian Truckers Forum' started by james1974, Dec 31, 2012.
Same setup as my truck, except mines only a tandem and no a-box.
I've pulled a few heavy coil tubing spools(60k) and keep it 13-1500 range.
Found this as well:
james1974 Thanks this. -
just kidding, Happy New Year!! -
Yea I usually don't let it get below 1200
Max torque is 2,050.
I would also say that the sweet spot is 1200 - 1400 and I would think that the max HP is at 2100. Which I would use the high RPMs to get moving or on a hard pull climbing a hill or mud up to your ying yang.james1974 Thanks this. -
I use the same engine, they don't pull anywhere near as good as the older ones. Not sure what you call a hill, 100,000 kgs. @ 1150 rpm...
IMO your completely wasting your time bogging down to 1150 rpm. Pulling a hill @ 100,000 kg. you should be downshifting @ 15-1600 at the latest. Peak torque at at 1200 rpm or something doesn't mean a lot as the torque curve is probably pretty flat after that. Horsepower plays a huge role in power. Torque plus horsepower equals power. Horsepower comes at high revs and with a fairly flat torque curve, the engine makes more power at a higher rpm.
Those truckers that gear their trucks to run down the road at peak torque are hauling ping pong balls and lawn furniture, any real weight requires power and power comes with higher revs. Sure torque gets a load up a hill, that torque comes from your drive line, the engine makes the power and the transmission/diffs converts it to torque. Now I must go pull some hills, Hudson's Hope to Boundary Lakejames1974 Thanks this. -
My truck is geared to run at 1600 rpm on the hi way and the engine does good at 1500-1650 range when i accelerate, but as soon as I start up a hill at those rpm's it has no holding power at all. The engine does not start to hold until the rpm's drop under 1400. I could just keep dropping gears and use the mechanical torque advantage that I get in the lower gears, but if I am not hurting the trans I figure why not use the engine the way that Cummins engineers designed it to operate. I only have 35,000 km on the engine now, so I am hoping that after 70,000 or so km it will loosen up some.
