New cb squelch rf gain ?
Discussion in 'Experienced Truckers' Advice' started by 4wayflashers, Feb 12, 2016.
  1. 4wayflashers
    4wayflashers Road Train Member
    1,063
    1,230
    Mar 14, 2014
    Hey all. Got me a bearcat 880 and hooked it up in my truck with the built in antenna, FL cascadia. Did the Diagnostic's check and everything is good. Anyone can tell me how I should set the squelch and rf gain?
  3. TAfool
    TAfool Medium Load Member
    631
    850
    Dec 8, 2012
    Everybody has their own preference; here's mine:
    A two step process. For regular monitoring:
    Turn squelch full off.
    Increase squelch until static ceases then go just a touch more
    Now set local:
    Press and hold RF Gain button to enable Local RF setting. Turn channel selector to lower the gain to the desired decrease (scale is 1 min to 5 max. Try 2 or 3).
    Press RF Gain button again to lock that setting.
    Once you have it set just hit the RF Gain button to drop the weaker signals and weed out the trash.
    I usually just leave mine on regular and nudge the squelch up to keep the weeds out. Only when it gets really dirty do I engage the BS filter (hit the local setting)
    TA
    KB3MMX, 4wayflashers and TheDude1969 Thank this.
  4. 4wayflashers
    1,063
    1,230
    Mar 14, 2014
    Thanks. So am I supposed to here static all the time?
  5. TAfool
    631
    850
    Dec 8, 2012
    No. Turn the squelch till the noise is gone.
    TA
    4wayflashers Thanks this.
