New CB not working.
Discussion in 'CB Radio Forum' started by Bob9814992, Jul 23, 2013.
  1. Bob9814992
    Bob9814992 Bobtail Member
    41
    15
    Feb 18, 2012
    Indiana
    I just bought a new Cobra LTD classic and put it my truck and I cannot receive static or anything else even with the squelch turned off. The truck is a 2008 Volvo 780 with the Rami multiplexer and dual factory antennas and a good external speaker. The antennas are new. Because this set up didn't work, I installed a new antenna, with new bracket and coaxial cable on the passenger mirror. I still could not get anything. I set the SWR with the gauge on the CB and it appears good. I have green lights on the TX and ANT. When I key the mic the TX and the ANT turn red, the RF meter swings to the right, and I don't hear the Beep. I called Cobra Tech support who talked me through the CB set up. He had me turn the DynaMike and RF Gain to the max and the Squelch counter clockwise until I could pick up anything. Because I still would not pick up anything he suggested it was a defective radio. I exchanged it for a new one and am still having the same issue.
    I know the multiplexer system does not have much reach but I would think I should get static at least. I don't need to reach the next county. I just want to be able to communicate with those shipper/receivers who still use the CB and to find out what is going on when I am in a back up.
    I don't understand why a new radio, antenna bracket, and coaxial cable will not work on the mirror arm. Originally, I had a similar set up using an old Stryker CB, old antenna, old bracket, and old wire and it worked great until a month ago. At first, I thought it was the radio, but obviously I was wrong. I have driven several different trucks and have always hooked the CB and antenna up with no problems. This has me stumped. Any help would be appreciated.
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    I think its a 08 Volvo 780 thing.. is yours red too? Lol
  4. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    Since this is your 3rd radio, its not the CB.
    In the first paragraph you mention external speaker, suspect it is bad or not connected properly ext spkr/ PA spkr switched.
    disconnect the external speaker to see if you hear anything, if not check that radio is set to CB, not PA.
    Bob9814992 Thanks this.
  5. Bob9814992
    41
    15
    Feb 18, 2012
    Indiana
    Nope, Desert Sunset, ie piece of ##### brown.:biggrin_25510:
    External speaker is good. To help figure out the problem, I set up another radio in my pickup truck then kept switching units and speakers between the two trucks. Everything would work on the pickup truck but not the Volvo.
    Radio is set to CB. The Cobra Tech walked me through all of the settings. Is it a ground problems?
  6. Ridgeline
    22,112
    113,286
    I would first rule out the radio, don't laugh at this but take a piece of wire - any single wire - four or five feet long and trim back the insulation on one end. then stick it in the center of the coax connector on the radio to see if you have any activity on channel 19. If not flip through the channels and see what happens. IF you do have any activity, then you can rule out the radio.
  7. Bob9814992
    41
    15
    Feb 18, 2012
    Indiana
    Are you suggesting I stick it in where the antenna hooks to, using it as an improvised antenna? I am willing to try, but I can't see me getting two bad radios from the same store.
  8. Budha
    Budha Light Load Member
    142
    138
    Jun 23, 2012
    Here
    Go buy a cheapy plug for the radio , pull the end apart and just have your negative wire and positive wire and wire it straight to the battery and see if it helps...maybe its something with your cb posts
  9. Ridgeline
    22,112
    113,286
    Exactly, this will allow you to see if it is an antenna or a radio. If you get any signal on the S meter and even noise, then the radio is working.
    AND yes you can get more than one defective radio from the same place. A lot of them can be referbs or overstock rejects that end up on store shelves.
  10. Bob9814992
    41
    15
    Feb 18, 2012
    Indiana
    Well I finally got the CB to work, but don't ask me how. I tried various things including setting up an old radio and antenna in my pickup and the new radio and antenna in my wife's car to see if the radio was good. Nothing. I got my old galaxy out and hooked it up in the car and got a signal. It worked some what so I put the Galaxy into the Volvo and got nothing. I remembered reading somewhere about the coaxial cable (18 ft) causing problems if it was looped over itself and mine was just stuffed into the overhead compartment in a pile. I pulled it out and let it fall outside the window; nothing. Then I hooked a long wire from the antenna bracket with the intentions of hooking it to the frame for a ground. I had to loosen the bracket bolt to hook the wire when I tightened them back down the radio started working before I had attached the ground wire to the chassis. I pulled the extra ground wire off and it still worked. I looped the coaxial into the trucks overhead in long loops to minimize crossovers and it still worked. Then I put the radio into the overhead and it still worked. I suspect that the antenna bracket was not grounding to the mirror arm; despite sanding the coating off. When I loosened it up to attach that ground wire it finally hit a good ground spot. Thank you for all for your suggestions.
    TheDude1969 Thanks this.
  11. Xcis
    Xcis Medium Load Member
    498
    270
    Jul 9, 2008
    Bridgeport, Pa
    Just incase someone is reading this thread, I would like to clarify one small point. If you have excess coax cable do NOT just coil it in a small tight loop. I suggest that you store your excess coax cable in a figure 8 pattern that is about 12 inches in length and secure the shape with a little duct tape.
