New Big Tex Trailer?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by nvmyrc51, Dec 29, 2018.
  1. nvmyrc51
    nvmyrc51 Light Load Member
    53
    10
    Dec 18, 2018
    Florence, KY
    Maybe it is just the first that I have seen it but it is a 31' deck over with a 9' hydraulic dovetail instead of mega ramps for a total of 40'. Anybody have any experience with them?
  3. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    I've used a midsota one of those a few tines, works nice as long as it works right, a real pain in the butt if the battery for the hydraulic pump is dead though.
  4. ast26909
    ast26909 Medium Load Member
    408
    264
    Mar 1, 2018
    Hydraulic dovetail is good for drive-on but the tail can't support a lot of weight.
  5. nvmyrc51
    53
    10
    Dec 18, 2018
    Florence, KY
    Big Tex claims 8000lbs on the dovetail.
  6. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    8k lbs lift capacity, or hauling capacity?
    Not sure on the Tex, but some others are only supposed to carry weight on the first half of the tail length. So your 40' deck becomes 35' of actual useable deck space. That'd be one of my biggest concerns with a hydraulic tail trailer. On a 40' hotshot you need all of it sometimes..
  7. nvmyrc51
    53
    10
    Dec 18, 2018
    Florence, KY
    Yea they don't specify if it will "lift" 8k but I am going to check it out tomorrow.
    singlescrewshaker Thanks this.
  8. ast26909
    408
    264
    Mar 1, 2018
    Another option is a 'tilt bed' trailer, 2 companies make this kind LoneStar trailer and Kerr Bilt with this trailer you can run empty container for ground delivery, pay very well.
  9. nvmyrc51
    53
    10
    Dec 18, 2018
    Florence, KY
    Will be getting a trailer soon. I am pretty much down to Gatormade or Big Tex. 40’ but still haven’t decided on hydraulic dove tail or flip ramps and is air ride worth the extra money? How about 17.5 wheels vs 16’s?
  10. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    You can get 14 ply 17.5s, not sure if you can get anything heavier than 10 ply for 16s.
  11. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    At the absolute MINIMUM get 14ply load range G for the 16" wheels. My trailer ate them garbage 16" 10plys for breakfast, lunch, afternoon snack, & dinner. 98% of the 10plys are only speed rated for 65mph, & on top of that didn't even live up to it. I've got Samson gl285T 235/80r16 14ply 75mph rubber & have been tire issue free since.. (about 19 months) There is a much better selection in the 235/85 series rubber but they stand about an inch taller. If ordering a new hotshot I'd get the 215/75R17.5 duals in 16ply for 12-15k axles and make sure they are speed rated at least L..(75mph) Worth the money IMHO. Also I don't have anything against the big tex trailers, I'm just not a big fan of the 22GN. 12" 16lb per foot main beams, with no frame bridging is ok for about the 32' & shorter trailers, but to thin for anything longer. It looks to me it leaves the 40'ers a pretty floppy ride. If buying a big tex I'd get the 25GN. It has a bit heavier 19lb per foot main beam..
