New 2014 Volvo and no fault codes menu in diagnostics.
Discussion in 'Volvo Forum' started by alex6999, Nov 8, 2013.
  1. alex6999
    alex6999 Light Load Member
    81
    9
    Sep 19, 2009
    Toronto, ON
    I have new 2014 670
    and no faults codes in diagnostics menu.
    what is it? volvo wants more money for diagnostics? leave truck we look it tomorrow... next week.... next year(it not a joke, it was dec 15)
    Anybody have same issue? or it just special version for me.
    PS: I am not working for large company who can lock this menu from driver.
    If you buying new truck ask dealer, maybe it will unlock it for free before you buy, not after.
  3. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    What? :biggrin_2554:
  4. NoCoCraig
    NoCoCraig Road Train Member
    2,604
    1,695
    Nov 7, 2010
    Chattanooga, Tennessee
    I believe what they are saying (very poorly) is that the diagnostic codes are not showing on the dash screen, just the check engine and stop engine message. This is a selectable setting in the ecm. There are multiple levels of messages that can be displayed but if turned off, you have to hook it up to a computer to read the codes.
    flood Thanks this.
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    I believe the last 5 we got only give u the Sae fault like mid pid and fmi in different format u have to hook up with a laptop to get the fault code also the diagnostic connections went to obd format no more like it used to be
  6. wizzy789887
    wizzy789887 Bobtail Member
    10
    8
    Nov 13, 2013
    Vancouver BC
    The new OBD Volvos no longer display inactive codes like the previous versions did. Also the new Volvos lock out diagnostics unless the park brake is set. When you see the new codes they report as follows. SA 0 (engine reporting) SPN XXXX identifies which system FMI 0-31 tell what failure has occurred.
    The MID/pid-sid/FMI now only applies to ECU's other than engine. These formats apply to all US10 and newer trucks.
  7. shijolazar
    shijolazar Bobtail Member
    what is this DTC P269800 FAULT Code. i see on my volvo truck. is this critical? let anyone pls comment.
  8. khalidjamal123
    khalidjamal123 Bobtail Member
    32
    5
    May 15, 2016
    Hi guys. I have the exact same problem! It is a 2014 VNL 670 with a Cummins. When trying to access the menu for DIAGNOSTICS only the the cluster tests show up. I can't get to the engine codes or any other codes for any part of the truck. Please help me if anyone has had the same problem and what was the fix. A European mechanic said it was in the cluster. any insight would be helpful. thank you.
  9. khalidjamal123
    32
    5
    May 15, 2016
    Alex6999, did you ever figure out the fix for the problem with your truck?
  10. Classico
    Classico Bobtail Member
    14
    6
    Mar 12, 2018
    did you find the problem with this code? just got it in my truck. could you share the solution if fixed ? thanks
