new 06 freightliner columbia day cab questions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by richie rich843, Aug 9, 2015.
  1. richie rich843
    richie rich843 Bobtail Member
    4
    Hey guys and gals well was looking for some advice ive recently purchased an 2006 freightliner Columbia with a 12.7 Detroit 60 really pretty clean blue motor.This is my first truck i bought it from Ryder with 416,000 miles on it and its just super clean inside and out wanted to know im kinda new to this what are some things to watch out for with this motor, is it a good motor,also it has the ultra shift automatic in it as well. Im going to be doing mainly local containers bumping around town.what ive really read is to take and send off a coolant sample as well as a oil sample is that correct also does anyone recommend somewhere to do that?any other preventive maintenance i should do and keep extra care on? Im super nervous about this its a big step for my family and i but im super excited just kinda worried as well,any help is greatly appreciated
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,593
    6,693
    Aug 26, 2014
    If the price was right you have chosen well except for maybe the automatic. I would suggest to find a good independent shop with experience from a major leasing or trucking company for regular maintenance and have an inspection done. I thank Ryder has a 30 day limited warranty period. If something like a wheel seal leaking,that you do not see, is found they can pay for it this month instead of you next month. You will need an annual inspection done and can kill two birds with one stone. May be better off going to a specialty shop, Freightliner , or Detroit for major repairs. Talk to truckers in your area and follow these important points. Work smarter not harder. Do not neglect your truck or family. Find a good accountant. Good luck!
    richie rich843 Thanks this.
  4. richie rich843
    4
    thanks for reply i appreciate it a lot i bought an extended warranty 1 yr that covers eng trans and rears so hope that will help with money if something happens, Defiantly going to take it to somewhere he locally as soon as i pick it up on wends im far from a mechanic for sure but hopefully will learn some basics to get buy i think they said they got the inspection done last month so hope its true they said card was in paperwork folder. The trans does worry me a bit hope ill luck out anything other advice maybe some special things to keep and eye out for? Also how about sending coolant and oil sample off do you recommend anywhere?
  5. richie rich843
    4
    heres some pics
      File size:
      131.7 KB
      68
      File size:
      175.4 KB
      61
      File size:
      118.1 KB
      78
      File size:
      152.9 KB
      71
      File size:
      138.9 KB
      67
      File size:
      139.7 KB
      77
      File size:
      143 KB
      77
  6. richie rich843
    4
    heres more
  7. BoxCarKidd
    4,593
    6,693
    Aug 26, 2014
    I just do not like autos other than maybe Allisons, I have limited experience with them but the last one I drove worked pretty well. Someone posted on this sight that creeper mode could be programmed into into these new trucks. If it is not set up that way Ryder could possibly reprogram it for you. You can find that under the search area and I thank that would be a big plus. If Ryder did an inspection but if does not have your name on it I do not thank that is legal for your annual and you will have to get that done. They way do that for you if you ask. Company's I worked for had samples done through their oil companies. Kits can also be purchased from Cummins, Detroit, Freightliner etc. I grew to have little use for oil samples, in 1986, but must reconsider after reading posts such as Cowpie's and Grape Ape's. Search when or how often to change your oil. I somewhat disagree with him but he made educated comments that changed my point of view.
  8. Exiled
    Exiled Light Load Member
    181
    29
    Apr 20, 2013
    Bought three trucks from Ryder, all had electrical issues.
    Checking the harness is not so easy, usually it's patched ,ECM had been worked on, after a year or so you might noticed unexplained glitches and break down.
  9. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    I had a 07 Columbia. The first issue I ever came across with it was the fuse for the ultrashift kept popping at about 800k and reading fault. So I put a paper clip into the fuse slot and said to my self "if it catches fire" then by all means burn mofo. That truck lasted to about 980k before the turbo was replaced and then the xy shifter. Then the trans at like 1.1mill and then sold it. It wasnt the gratest investment but it made money I'm the mean time.
    A dyno will let you know a lot about your truck.
  10. ribella
    ribella Bobtail Member
    18
    May 18, 2015
    I bought a 2008 Columbia on 2/23/2015 from Ryder, since then i spent $8k and only drove it 20,000 miles because of unexplained glitches.
    like others said you might noticed unexplained glitches and break down.
    the warranty you bought doesn't cover nothing and if it does it will be at the dealer for a month before the repairs get approved.
    Good Luck
