Need windshield squeegee ideas: What do you use/recommend?
Discussion in 'Experienced Truckers' Advice' started by Russian Rabbit, Jan 21, 2019.
  1. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    Need good squeegee ideas:
    1) Should be long enough to reach the windshield from the ground.
    2) Portable would be nice, but not totally necessary. Requirement #1, above is more important.
    Thanks.
  3. rabbiporkchop
    9,675
    6,523
    Feb 9, 2012
    Wapwallopen, Pa
    I recommend the Ettore Pro Series 14 in. Backflip Squeegee and Washer Scrubber
    And a telescoping pole with a 3/4" acme thread to screw onto the squeegee.
  4. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    Any janitorial supply store
    tscottme Thanks this.
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    I keep a telescoping pole with a brush in my jockey box. I also keep a 2 gallon tank sprayer, the kind you would use to spray weeds in your yard. Scrub the windshield, door windows and mirrors with soapy water, then spray them down with clean water from the tank sprayer. Does a much better job than those crappy squeegees at truck stops with no streaks and it's a lot faster.
    SoDel and Russian Rabbit Thank this.
  6. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    What are you going to use for soap/water solution and bucket away from home? PFJ's are good about keeping 5 foot squeegee's at every pump with a winter solution glass cleaner
  7. Russian Rabbit
    1,701
    1,633
    Jan 3, 2016
    Windex.
    Linehaul drivers never go to truckstops, unless to get something to eat.
    rabbiporkchop Thanks this.
  8. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    If you can find your own collapsable or telescoping squeegee and blade, I'd prefer using gallon-water and Dawn soap solution made up in a drywall mud pan. In winter you can maybe get by with windex but it seems easier to use a soap/water solution (or winter washer fluid in winter), scrub the glass, then squeegee clear, then toss the rest of the solution. I've had good luck in the past with this setup when I did not frequent truck stops or the fuel island did not have the necessary stuff.
    Russian Rabbit Thanks this.
  9. JoeyJunk
    JoeyJunk Road Train Member
    8,763
    68,024
    Dec 31, 2010
    Washington, PA
    Lowe’s also has squeegees in the cleaning products area and the extension pole in paint area.
    Russian Rabbit and D.Tibbitt Thank this.
  10. ncmickey
    ncmickey Road Train Member
    3,820
    7,104
    Jun 21, 2013
    Durham NC
    They are also good with having a quart of oil and deisel fuel in the bucket....
    D.Tibbitt Thanks this.
  11. D.Tibbitt
    140,748
    Along with ppls snot rags and probably hepatitus c and some weird flip floperitus thats very contagious when getting on ur shoes it will give u the urge to wear sweatpants and flip flops
    mustang190, motocross25 and ncmickey Thank this.
