i got exhaust leak behind turbo on isx, want to take it down too see whats going on. Does anyone know where can i get diagram of disassembled turbo ?
Need Turbo diagram for ISX
Discussion in 'Trucks [ Eighteen Wheelers ]' started by vadim2200, Mar 22, 2011.
well its either turbo mounting gasket, manifold gasket, or its the clamp on the back of the turbo that connects to the exh pipe. they're not that difficult to take off and reassemble. your best bet would be make a friend at the local dealer who can print you pics off cummins.
not exhaust manifold, and not gasket that connects turbo, i was thinking about that clamp too. About the pics from Cummins- I was thinking about buying isx Service manual book but i dont think it covers external parts of the engine, like: starter, AC, Turbo, ...other.
Go here:
http://www.holset.com/mainsite/files/4_4_1-service repair manuals.php
Then select 500 series. Then select he551v. -
what is the engine ser. #i may be able too help.I am a cert. ###, cat,det tech.
Be very very very careful when disassemblein that joker because its so tight clearance and you will bend the turbine fins.
