Need to replace ecu, def has been deleted
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Lgaff, Apr 5, 2022.
Thread Status:
Not open for further replies.
  1. Lgaff
    Lgaff Bobtail Member
    43
    22
    Feb 2, 2021
    Hi. I have a 2012 Peterbilt 386 and the def has been deleted. The ECU went out and needs to be replaced, but the dealership is refusing to work on it because the def has been deleted. Is there a way that I can get the new ECU put in the truck, and programmed, but keep the def deleted? I am assuming since I bought this truck used and the def was deleted which is common on this model, that it is just going to cause more issues in the future if I have the emissions system reintegrated. I would appreciate some help with solutions if available. Thanks so much!
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    Find a local tech that will do the work.
  4. kranky1
    kranky1 Road Train Member
    2,253
    8,850
    Sep 16, 2015
    Ontario, Canada
    Their hands are tied, they can’t work on it or the EPA will tack their hide to the barn. About your only choice is to drag it out of there. If you have to replace emissions parts, on a truck that old you’re going to, an ecu and whatever else they find, to legal the truck up I’d expect $15-$20k. Or get a chain. Once you get it out of there find an ecu, get it PDI’d or Diesel Spec’d like the old one and screw it on. To fix the emissions I can’t see being cheap, or quick. Ask them if they have all the parts in stock first, and what it’s going to cost. Take a bucket, you may hurl when you find out how long and how much.
  • Thread Status:
