Need to order rebuild kit for fifth wheel
Discussion in 'Peterbilt Forum' started by BrandonC83, Apr 8, 2015.
  1. BrandonC83
    BrandonC83 Bobtail Member
    I have a 1985 peterbilt 359 has a holland fifth wheel underneath I found a casting number xd-3501 - nothing comes up under xd it's all xa - does anyone know what kind of kit I need and why the xa-3501 is all that comes up.
  3. passingthru69
    on the side should be a metal plate with the model number. or go to Pete with your trk. s/n number and they can look up the model 5th wheel you have
  4. KW PARTS
    KW PARTS Bobtail Member
    4
    Apr 29, 2014
    That casting # is for a FW3500 top plate. You need a RK-63501 rebuild kit if it is left hand pull.
  5. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    They ain't cheap.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Ordering component parts by truck serial number can be a problem if you do not know they are original. Holland 5th wheels are very good but frequently require welding and grinding to fit the yoke to bottom of the plate. They used to come with instructions to do that but the last kit I saw just had allowable wear limits but I welded and ground to fit. Just trying to let you know it is probably not as easy as you may thank, consider exchange, new, or professional help. If you have those abilities and desire to it's not that hard but the liability is high. Anybody please correct me if you disagree.
  7. bad-luck
    bad-luck Road Train Member
    3,252
    5,955
    Nov 16, 2013
    Baltimore, Maryland
    there should be a plate somewhere on the front of the fifth wheel or the side indicating the model and serial number. It's very easy to rebuild. I've done it myself takes about an hour and the rebuild kit costs around $280. Only thing I would suggest if they have someone hold the diagram for you to put your hands get so greasy. I would however make sure the top plate of the fifth wheel isn't worn out as well. because a new fifth wheel is only about $800 depending on what brand you purchase.
