Need to know where to get CB radio mounting bracket for Cascadia
Discussion in 'Ask An Owner Operator' started by Shotgun94, Feb 14, 2019.
  1. Shotgun94
    Shotgun94 Medium Load Member
    446
    301
    Sep 24, 2017
    Georgia
    I want my cb radio in the cubby above my head next to the net. I don't have the holder with the holes for the mounting bracket. I can either drill me some holes through it get one but I don't know where to get that metal bracket?
    It is a metal bracket that holds the cb to the plastic holder. Some of them are just for holding glasses and others are for holding your cb in place. Thx in advance
  3. Crazytrucker77
    Crazytrucker77 Heavy Load Member
    846
    1,036
    Nov 23, 2014
    Grants Pass, OR
    Ok I am just a little confused. Are you looking for the cb unit mounting bracket or for a spot to mount the cb?
  4. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    cb mounting bracket. not a spot.
    but I suppose on the dash will do as well.
    The cb metal bracket will bolt to this picture above. which bolts into the cubby hole above the head.
    There is a metal bracket that connects the two so the cb doesn't slip out of the slot while driving.
  5. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Try chrome shop
  6. Opus
    114,712
  7. RockinChair
    RockinChair Road Train Member
    4,918
    12,257
    Feb 19, 2012
    CC, TX
    Should be another one behind the other plastic piece on the other side of the overhead console. If not, you can get one from your local Freightliner dealer or you can "borrow" one from a spare truck on the yard.
  8. Shotgun94
    446
    301
    Sep 24, 2017
    Georgia
    Thx guys, I'll look into those and that Atlanta truck junkyard!
  9. Crazytrucker77
    846
    1,036
    Nov 23, 2014
    Grants Pass, OR
    Ok that is what I figured but wanted to make sure. I second a freightliner dealer or a chrome shop. One piece of advice though for wiring it in. Unless there are wires there stock for it make sure to run some from the fuse box. You don't want to splice into another circuit. There is a good chance you can overload it and cause problems with your electrical that will run you way more money then having a dedicated circuit put in.
  10. Shayno3
    Shayno3 Bobtail Member
    6
    Apr 9, 2020
    Hey I'm looking for that same metal bracket did you ever find a place that had them in stock? I can't find it anywhere please help
    Shotgun94 Thanks this.
  11. Shayno3
    6
    Apr 9, 2020
    Hey did you ever find that bracket ? I'm looking for that same metal bracket and I been checking everwhere
