Need to fix some broken air cleaner studs
Discussion in 'Western Star Forum' started by fortycalglock, May 20, 2015.
  1. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I've got a couple studs that broke off when I pulled the top off to change air filters. Does anybody know the proper way to replace them?
  3. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    Freightliner has no good way to do it. I went with cutting the welds on the old broken studs. Then getting stainless steel bolts with 3/8" threaded body clips and just screwed them in from the top. the right way to do it is, remove the housing and grind off the old weld. Then weld in new grade 8 stainless steel bolts.
