I have a cobra 29ltd classic
I have a Wilson 2000 antenna that is tuned properly but I'm still only hearing static on all channels
I can see the meter moving when people talk, but still just static
What can I do from here?
Need some help with Cobra 29ltd Classic.
Discussion in 'CB Radio Forum' started by MilkOnMyWhiskers, Jan 27, 2019.
You should have a SWR meter on the left, there should be a SWR Calibration dial on the face, calibrate that.
Then reduce the squelch until you get a signal.
If you don't have much besides static, then I suppose there isnt anyone talking that close to you yet. -
When you say antenna is tuned properly does that mean you checked the swr and it is acceptable? Not to imply you are clueless, I only ask because I have encountered individuals who were under the impression that all they had to do was set switch on cal, key up and turn cal knob until needle was on 1 and it was set not realizing that swr is adjusted at antenna not radio, radio or external meter only checks swr.
rabbiporkchop Thanks this. -
Can you make a video of you doing a radio check and let us see what you're getting back? Also post 4 is good advice. You said it's tuned properly. Do you know how to tune an antenna? Some people don't. Not calling you an idiot.
