need some cheap dunnage????
Discussion in 'Flatbed Trucking Forum' started by snowwy, Oct 9, 2013.
  1. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    i know you all keep what ever lands your way in picking up loads or what not.
    but just in case your hurting and need something.
    home depot has landscape timber for $4. 4 x 4 x 8. 2 sides are flat. 2 sides are rounded.
    and if you absolutely have to have square. that's $7.27
    the going rate was $10 3 months ago.
    fisher guy Thanks this.
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    You know it needs to be hardwood, snowwy.:yes2557:
  4. snowwy
    20,525
    13,261
    Jul 6, 2009
    how much harder does wood have to be compared to wood????
  5. passingthru69
    Well when you put 50k on wood you need it to stay in the form it was, not flatten like a pancake..
    SHC Thanks this.
  6. windsmith
    windsmith Road Train Member
    7,296
    6,031
    Sep 2, 2011
    NEPA
    wow. Just... wow.
  7. KW Cajun
    KW Cajun Road Train Member
    2,383
    3,652
    Apr 12, 2013
    Copperhead Road
    Yep, the landscape timbers are usually SYP (southern yellow pine) impreg'd with creosote-like substance, and a "soft wood".
    Oak is the most common hardwood.
    If the neighbors are gone, a nice sturdy limb from that beautiful live oak in their back yard, cut and rough-hewn, should work fine.
  8. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    I got away with using treated 4X4 lumber that I liberated from a shipper to place under their crane mats that I was hauling. I used those until I got a steel building kit load that was riddled with heavy, rough cut 4X4 oak timbers as dunnage. When the load came off, eight of those timbers stayed on my truck and the treated wood was left with the receiver ;)
  9. snowwy
    20,525
    13,261
    Jul 6, 2009
    this landscape timber was just as hard as the $7 dollar stuff. should hold up just as good as other wood i've had in the past.
    i've got a brand new trailer. (3rd load) with no wood. and my load required i supplied my own dunnage. so, home depot got $32 of my dollars for 8 boards.
    cheaper deal then the $10 a board i've been paying in the past when i've need wood for a load.
    i've been getting a lot of loads lately. where i've had to supply my own wood. shippers are getting cheap these days.
  10. windsmith
    7,296
    6,031
    Sep 2, 2011
    NEPA
    Shippers tend to come up with dunnage pretty quickly when you let them know that you're leaving empty. You should try that sometime, it might save you $32.
    SHC Thanks this.
  11. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I don't carry a load just to pick up a load. Shippers provide their own dunnage and receivers get to take that with the product. If you're shipping a million dollar machine and you can't come up with your own 4x4 or 6x6, that is not my problem. If I carried everything a customer has ever wanted me to supply, I'd have no room for actual freight. I supply tarps, padding for my tarps and tie downs.
    j3411 and SHC Thank this.
