Why is there 2 giant spacers on the passenger side old motor mount.bushings? None on other side. Had to cut these out. The metal sleeve that usually stays put in bushings pressed in to these pacers. Same part numbers on new bushings. Do I keep these out?
Need quick response. Pete 379 rear motor mounts
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, Sep 3, 2018.
The steel spacer keeps you from over tightening the bushing and squeezing them out. They should be the same both sides. Someone put rubbers in one side without the spacers.
Dino soar, Oxbow and Oldironfan Thank this. -
I see what your saying. The super thick washers do not belong. Only the 1/8" ones top and bottom.
Oxbow, pushbroom and Oldironfan Thank this. -
