Need Opinions on Cummins ISB6.7 on Freightliner M2
Discussion in 'Freightliner Forum' started by Zans, Feb 1, 2021.
  1. Zans
    Zans Bobtail Member
    4
    Looking to purchase a 2015 Freightliner m2 with a cummins ISB 6.7L engine. Does anyone have any experience with this motor on a medium truck in the long run? I know its probably fine, on pickup trucks and RVS, not hauling that much weight, but just unsure how it'll do on a straight truck.
    I personally feel 6.7L is a small displacement size for a medium size truck. We haul upto 12,000 LBS, and i feel this engine just sounds too small to be hauling that kind of weight in the long run. The other cummins motors for medium trucks are 8.3ISL, 8.9 ISL, which is my preference but not available .
    However against my belief, i have read the ISB to be a reliable motor and also powerful in terms of creating 1000 LBS of torque. But it is only 220 HP. Not too sure if Torque is more relevant or HP in my situation, we drive about 200 KM everyday in the local, on average hauling about 8000 LBS but can go upto 12,000 LBS once or twice a week. I personally feel hauling that kind of weight on a 6.7L motor strain it over time, ultimately shortening its life span, however i have seen this motors on trucks with 600,000 KM, but im not sure what kind of weight they hauled.
    If anyone has any experience with this motor on a straight truck, please let me know what you think. O
  3. Flint1
    Flint1 Road Train Member
    1,137
    9,748
    Sep 4, 2019
    Alberta
    The 6.7 ISB is the default choice for all 3 north American school bus manufacturers. They haul all day, everyday. Great on fuel. As with most modern diesels the harder they work, the less emissions problems you will have.
    They mainly have issues with the variable geometry turbo, and the usual def issues common with most new diesels. But the core engine is excellent.
  4. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Work on them almost every day. Weak spots are in the egr system. Small egr cooler and the differential ports plug up frequently. Egr valves along with ports can be removed and cleaned easily with a 10mm socket and a sharpened coat hanger. Overall a strong engine. Use a cetane fuel additive. You will be O.K.
  5. Hulld
    Hulld Road Train Member
    2,882
    6,564
    Oct 19, 2015
    Upstate NY
    I have one in a 2008 pick up that has been trouble free.
    Your probably thinking “ yea trouble free in a pick up truck pulling no weight”
    Well I pulled commercially with mine at a GVW of 45,000 lbs and it is now used for personal use pulling my 40 ft fifth wheel camper.
    Honestly 12,000#s to that engine is a joke.
    I also have a 2002 fl 60 Freightliner rollback with a 5.9 Cummins in it that has 446,000 miles on it and it has a GVW of 25,500 # and it also has been very reliable.
  6. Colt6920
    Colt6920 Light Load Member
    177
    260
    Apr 28, 2017
    Pretty standard motor for that application. School buses, single axle medium duty trucks, etc.
    The reason its only 220 horse is for longevity. In a pickup application they get the stupid high power and torque but they only do that because they know most of the time they are loaded light. Even in the Ram chassis cabs (the ones they put service bodies and flatbeds on) they are derated to a lower power rating as they know those will be worked hard, and lower power=longer life.
    If you want to test it out call up Penske or Ryder and ask for a Freightliner M2 (should have an ISB+Allison, but make sure). Rent one for 250 a day, haul some typical loads with it, and see if the 220 HP is enough. To me, they are fast enough for a truck. I can merge without creating a hazard while loaded, and to me that's plenty fast.
    Zans and QUALITYTRUCK Thank this.
  7. Itsbrokeagain
    Itsbrokeagain Light Load Member
    155
    199
    May 31, 2019
    We have the 325hp one in our bucket trucks, coupled with the Allison 3000 trans. I use the exhaust brake/jakes as much as possible, I find exercising the VGT on the turbo has helped it from sticking up.
