Need help with volvo code: MID 130 PSID 27 FMI 8
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gursharn Toor, May 18, 2014.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    look at right side of transmission
    u can see valve unit and tube that runs inside bellhousing?
    New I=shift got clutch servocylinder of coaxial type
    it does not pulls diafragm of valve cover like of first i-shift
    it presses, like on cars
    CoyoteExpress Thanks this.
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    HI pablo,
    COde was a time gone but comes up again
    LAst time it gies from self
    ANy thing what i can clean or adjust maybe my self ?
    THx
  4. Nightrider1602
    Nightrider1602 Bobtail Member
    I have the same code with check transmission light on the dash. My ishift takes couple of seconds to engaged in first gear with a jerk but after first shift it is fine. Please help. Thanks
  5. famykool
    famykool Bobtail Member
    9
    Union City
    Has anyone been able to find a solution to this problem? I am having same issue. Specially when putting it in reverse. It goes away after few minutes though.
  6. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    did you ever find out the solution? Mine is ding the same thing. At first on Drive and on Reverse
  7. Hustler08
    Hustler08 Bobtail Member
    What if the transmission is changed along with the clutch would this code still pop up
  8. AlexD13
    298
    85
    Jun 13, 2016
    Mine ended up being the micro switch behind the pedal
  9. Bath
    Bath Bobtail Member
    7
    4
    Dec 12, 2015
    I had the same code, whenever I used to hold my brake pedal for few seconds at a stop sign or light this annoying code would show up and go away doing the same after sometime, so, I changed the Brake pedal micro switch and it immediately solved my issue ( thanks to Alex D13).
    AlexD13 Thanks this.
  10. Master2
    Master2 Bobtail Member
