Hi, I have a volvo with i-shift and I'm having trouble with the transmission. I'm getting this error code: MID 130 PSID 27 FMI 8.
Need help with volvo code: MID 130 PSID 27 FMI 8
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Gursharn Toor, May 18, 2014.
what year is the truck? it is clutch problem code
My friend has the same problem. Truck is 2009 on 430k miles.
Check engine fault just goes on then disappears.
There are no problems with shifting or anything. Also there are not noticeable air leaks.
Along with this code are :
MID 130 PID 160 FMI 1- once
MID 130 PPID 50 FMI 11 - once
MID 130 PSID 27 FMI 8 - 9 times
What can be the reason for this code? -
did anyone get a answer to what causes this code ?
I have the san´me on my fh 540 2011. -
2012 i shift onmmy one
clutch valve assembly
located on pass side of tranny -
pid 160 - shaft speed sensor problems
ppid 50 - clutch load problems -
Hi pablo,
On the MID 130 PSID 27 FMI 8 what brings this prob up
What can i check
Got the oilfilter replaced 1 konth ago and oil toped up -
looks like clutch control valvs are worn ore incominated with moisture
CoyoteExpress Thanks this. -
Did you have a ouc or diagram with the location of it pks
