need help with my cobra dv 19 iv
Discussion in 'CB Radio Forum' started by dfrench, Jun 21, 2014.
  1. dfrench
    dfrench Bobtail Member
    4
    Got a new cobra 19 DX iv but can't seem to get it to transmit or recieve . have a fire stick antenna and have it mounted to driver side of the bed of my truck. Don't know much about CB radios. My mic works because I use the pa part threw my stereo and heard my self talking so I need some help. I don't have a swr either.
  3. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    Is it a Cascadia? Do you get an antenna warning?
  4. dfrench
    4
    Don't really know what that is. Makes static noise. Start a low pitch noise now tho. When I say I know nothing about cb's I mean nothing.
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Reread his OP. It's mounted in his pickup bed....
  6. dfrench
    4
    On the driver side. Top of bed rail
  7. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Probably can't get the help you need on here because there is so much to check. My advice, if you have a friend that has been into CB for a while, or know a Ham operator, go see them and get some help and learn......it isn't very difficult to learn the basics and won't take but a few minutes to check everything out. Or go to a shop. But, beware of CB shops! Not all of them are what they claim to be. Again, check around before you spend any money in a truck stop CB shop. Even some with good reputations only have that, a good reputation, because they fooled the uninformed. Most of them are competent enough to check all your connections and SWR. But I wouldn't let anybody open my radio up unless I was convinced they knew what they were doing. Most old CBers and even some Ham guys are more than happy to help out a newbie.
    Big_m, handlebar and Turbo-T Thank this.
  8. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    dfrench, what area are you located? If you are close I'll help you out.
  9. mike5511
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Same here.........
  10. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    First things first...
    You say it makes static? That's with the squelch fully counter clock wise? Try unhooking the coax at the back of the radio. Does the hissing drop dramatically? If so, I'd say it's receiving somewhat.
    Next, you say the antenna is on top of the bed rail. How did you mount it?
    When you mounted the antenna, did you ground it?
    Where have you tried keying up the radio to talk at? Maybe there's no one near you with their CB on?
    Have you tried driving to a busy truck stop and flipping to channel 19 and asking for a "radio check"?
    Also what do you mean you do not have an SWR?
