Need help with Air compressor building too much air !
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Eddie2193, Feb 8, 2018.
  1. Eddie2193
    Eddie2193 Bobtail Member
    2010 freightliner Columbia CL 120 vin 1FUJA6CK7ADAT2936
    ISSUE : truck came in with building too much air issue , 130 + psi in the tanks both tanks .
    Here is what I have done so far:
    Installed a brand new secondary tank, reason was weld was leaking due to rust
    Brand new Bendix AD - IS drier and governor , Governor is non adjustable! and tried different adjustable governor same issue !!
    Replaced the unloaded valve on the compressor ,
    Tested compressor operation , stops pumping air to the tanks when I apply shop air to the hose from the governor to compressor ,
    Have no air leaks.
    Any idea or direction some one can point me to?
  3. Steel Dragon
    Steel Dragon Road Train Member
    2,681
    2,833
    Nov 23, 2015
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    130? HA. That's good. I'll take it.
    Rusted tank? Bye bye new tank please.
    Call me damaged. I'll do 150 if the truck would do it. There are times near the GWB I can spend it all in a hurry. I cannot stand weak trucks that max out at 80 pounds and then drip it out....
    Steel Dragon Thanks this.
  5. Steel Dragon
    2,681
    2,833
    Nov 23, 2015
    I just had my Compressor replaced but my truck is only 2 years old,shop says worn bearing cost me a power steering pump,vibration snaped the shaft from power steering pump.
    Another friend has his air compressor replaced and once down the road,started blowing out old air lines..:Traffic lights:
  6. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Make sure you put the original governor back on the dryer. You cannot install an adjustable/universal governor on that dryer or it will never work right.
