Need help! Side box door latch broke and won't open
Discussion in 'Kenworth Forum' started by sparky88, Jan 31, 2015.
  1. sparky88
    sparky88 Light Load Member
    143
    31
    Jan 22, 2014
    oswego, ny
    So I put a large bag of speedy dry, shovel and have other tools and stuff under my sleeper and my door latch broke so I need help!! Does anyone know how to get it open? And where would I find a new door handle assembly?
  3. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Get a new one from the dealer. Can you get under the bunk and unscrew the nut?
  4. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    what yr and model truck? If it's a T2000 I believe the bunk tilts up.
  5. mslashbar
    mslashbar Medium Load Member
    599
    802
    Jul 22, 2009
    elizabeth,co
    Not sure in a KW, but in a Pete you lift up the mattress and can get access to the side boxes by taking the plywood off.
  6. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Sorry forgot about model. 96 w900l. Bunk doesn't tilt up. I may end up having to cut a hole in the platform to get to the door access panel. I have to look again as it might be screwed in but it's metal not wood.
  7. Dale thompson
    5,101
    42,225
    Nov 20, 2013
    commerce twp,mi
    you will need a torx head to take out the screws under the mattress
  8. Lucar
    Lucar Road Train Member
    1,396
    889
    Aug 22, 2012
    Texas
    You have to drill the latch out
  9. mitchtazz
    mitchtazz Road Train Member
    1,826
    503
    Sep 6, 2009
    Lake Wales, Fl
    if your door is like the one on a t660, you can use a screwdriver to push the latch in once you gain access to the cubby from under the bunk.. depending on what part the of the latch that broke you can possible get it from a lock smith. if it's the handle you'd have to see the dealer or order online.. if it's the actual latch mechanism, then you can get that in more then a few places.. i bought one for my tool box from a local lock smith.
  10. sparky88
    143
    31
    Jan 22, 2014
    oswego, ny
    Awesome thanks guys! I was trying to find the assembly online but couldn't find anything. This week I'll mess around with it and see what I can figure out and take the piece out below my mattress. At least I will be able to get to some of the essential stuff.
  11. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Because you will need to remove the latch to replace it I would take a small air or electric grinder and grind the heads off the rivets on the outside of the door. Hopefully you could then remove the handle and replace it.
