Need help 97 379 Pete speedo problem
Discussion in 'Peterbilt Forum' started by Zseverns, Mar 2, 2014.
  1. Zseverns
    Zseverns Bobtail Member
    I have 1997 Pete 379 with a Detroit that the speedo isn't working. Already replaced the sensor on the transmission and the speedo head but it still will not work. What else is there that would cause it not to work.
  3. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    Broken wire. Bad ground.
  4. snowdrifter
    snowdrifter Bobtail Member
    4
    Check your DATA Harness firewall to cab Warning disconnect batteries before disconnecting the plug you do not want to power surge the ECM...
  5. TwinStickPeterbilt
    TwinStickPeterbilt Heavy Load Member
    707
    910
    Mar 16, 2013
    Time to get a new speedometer. I went through 7 on a 2000 Peterbilt 379EXHD. I'd look down and she'd just quit working.
  6. generallee
    generallee Medium Load Member
    512
    441
    Jan 4, 2014
    Mine quit the other day on an 03 379EXHD. 5 minutes later it started working again. Been fine so far. Anything in particular I should at when it quits and starts working again. The wiring issue mentioned here seems to make sense. Anywhere in particular I should check for this?
  7. Excorcist1
    Excorcist1 Light Load Member
    222
    39
    Jan 11, 2012
    Chestertown, MD
    I had exactly the same thing happening with the 07 386. It usually starts reading after I get over 30mph. But it's acting worse.
  8. OldPete379
    OldPete379 Bobtail Member
    17
    6
    Feb 18, 2014
    The plug on the back of the speedo unplug it and take a small flathead screwdriver and spread male connections open slightly. Ive done that a time or two on my 98 and worked fine again.
  9. Auto hauling
    Auto hauling Bobtail Member
    9
    Aug 28, 2018
    Chicago
    How can I trace Speedo sensor wires between the sensor and ecm on 2004 Pete 379 cat c15
    Thank you
  10. angelina
    angelina Bobtail Member
    Hello! Please need a help
    I have Peterbilt 379 1998 , i just checked it's show me that the speed sensor falls ,
    I'm trying to buy a new sensor , but i don't know exactly what kind i need to buy , how many speed sensor have in Peterbilt 379 1998? and where is located all 4 speed sensor.
    Please any advise
  11. Big Road Skateboard
    5,695
    29,704
    May 2, 2021
    Tailshaft of trans. It'll either be single lead or 2 lead.
