Need help. 2007 International 8600, hard starting.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SyracuseGirl, May 18, 2016.
  1. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    The Water Fuel Separator also acts as the Fuel Filter too.
  3. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Just had an identical truck with same issue. Cummins ISM with Daveco Fuel Bowl. Replaced the check valve in the fuel bowl. Part #DVC 101132
    Not every problem is the same though.
    You did not post important INFO. Engine type
    Heavyd Thanks this.
  4. SyracuseGirl
    SyracuseGirl Bobtail Member
    9
    Same Cummins ISM
  5. SyracuseGirl
    9
    The motor is a Cummins ISM
    The check valve fixed your problem?
  6. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Yes With the check valve not holding prime it will cause hard starts and poor suction of fuel. This would be where I would start for sure. Cheap and easy.
  7. SyracuseGirl
    9
    Thanks. I'll start there.
  8. BigPerm
    BigPerm Medium Load Member
    Right on...Davco filters are ready for replacement when normally "full".
    If that doesn't fix, check to see if there is a starting relay signaling the computer to fire the injectors. Prolly not tho'.
    Buy the Davco wrench too. Seem to remember they market a kit w/extra seals & check valve (s).
  9. SyracuseGirl
    9
    Thank you. Replaced the Check Valve. The old and new were different sizes. When I changed the first filter is when the truck started not starting without help. The ball must have changed positions enough not to create a seal. The new part worked great. It now starts on its own again. Still cranks a little longer than I would like, but at least it is firing up. Thank you for your help!
  10. BigPerm
    Right on....everyone was confused when the Davco came out. Glad it's fixed.
