Need guidance on load bars
Discussion in 'Experienced Truckers' Advice' started by BlackThought, May 5, 2018.
  1. BlackThought
    BlackThought Medium Load Member
    562
    462
    Jul 22, 2014
    Memphis,TN
    Been using straps since the beginning. I feel the need to carry load bars and straps. Reason being some times I can't get to a point to place the strap.
    My issue is not knowing which are quality and what to avoid. At ts I see some that are the usual long ones. And some that appear collapsed and are maybe 50 inches when not extended.
    So what do I look for?
  3. mem
    mem Light Load Member
    158
    227
    Sep 25, 2015
    Prime tells us to only use the ratchet style, supposedly they are the most trustworthy. I'd be careful using them on a dryvan, you can damage a wall with those.
    All of mine are the long black bar you just extend by hand and lock the handle in place, because that's what I've scavenged recently. I've never had a load lock fail on me in four years, so I don't worry too much about what the company recommends. On these you do have to watch out when they get old, the little metal nub can break off that keeps the handle locked.
    If you are using two load locks across the same plane, check the first one after you install the second. Sometimes the wall flex will loosen it some.
  4. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Always install bottom first then second which is on top or wear hard heat. Never install vertically. Roof is just skin
  5. Gumper
    Gumper Road Train Member
    1,532
    3,370
    Jan 7, 2018
    Butte, MT
    Hydraulic load bars are the bee’s knees, but they don’t last all that well. The lever style work pretty good. Always seems like they’re too tight ore loose though. Ratchet ones suck, or at least the ones I used did.
  6. Ridgeline
    22,098
    113,137
    Load bars are those that have a rated weight for both support and for securment, usually 2000lbs.
    These go into the e-track that is mounted on the trailer walls.
    Load locks have have no rating and are ratchet style or hydraulic and can go anywhere.
    I've seen drivers use load locks to secure loads that moved on them and still made a mess in the trailer becuase they are not designed to hold loads that are heavy.
    Chinatown Thanks this.
  7. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    Do you have a load lock rack on the back of the cab? If not, do you have a way to store them, other then inside a trailer?
    If you have e-tracks, straps is the best way to go. Sometimes you may need to work with the loader to attach an end before the final pallets are put in if getting a good "pull cinch" is critical
    Triple C Thanks this.
  8. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    If you do use long load locks, I recommend you remove them from the trailer and not rely on the fork lift operator to not run over them or bend the feet pads if they're moved over to the side. They are notorious for leaving them on the side on the floor as they load, and you will end up with severely bent feet pads sooner rather than later.
    Unless they specifically request me leave them in the trailer for them to apply, I back up close, remove them off to the ground, back in, then when loaded, pull up and put them in myself.
    But we do lots of freezer docks where we never open swing doors. They open from inside, load, close, and seal and we can only hope they were not omitted or tore up.
    snowwy and Buster Churry Thank this.
  9. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    The load bars sold at truck stops are the cheapest ones and break easily. Shop around for better quality.
  10. Buckeye 60
    Buckeye 60 Road Train Member
    1,229
    1,268
    Apr 19, 2018
    load locks don't work in a dry van unless the are the kind that hook in the e tracks and they are not any better than a strap
  11. magoo68
    magoo68 Road Train Member
    3,393
    5,384
    Jun 11, 2011
    st malo mb canada
    Load lock with a strap nearby will be pretty solid ..
    91B20H8 Thanks this.
