need draining air tanks advice.
Discussion in 'Questions From New Drivers' started by zoekatya, Oct 14, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    What is the best way to drain them? I usually turn the valves when I park fornthe night and leave them that way until the morning pre trip when I build the air back up because I don't want moisture building up over night. Am I doing it correctly. Is it bad to leave them open like that? Could they freeze during winter open? How many times should I drain them during the colder months? When I don't drain them the check engine lights cone on and I loose power to 55mph if I keep driving I loose power to 3mph and then have to do a regen. is this problem directly related to the air tanks not being drained enough?
  3. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    If your truck has a working air dryer (as virtually every modern truck does) you should not be doing as you're doing. When you open the valve, do you see actual water blowing out? I doubt it. Pull the cable or turn the valve momentarily once every several days should be more then adequate if your dryer is working. But do not leave open to drain all air. This is a waste of time and a runs a risk of having other issues.
    JReding and zoekatya Thank this.
  4. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    I wouldn't leave valves open all night in some of the cold states I run in..
    but I only drain my tanks 1-2 a season and then I do it when I am on a southerly run in warm weather.
    and
    The loss of engine power to 3mph is a regen issue not brakes.
    zoekatya Thanks this.
  5. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    I call troll on this thread and this needs closed by an admin.
  6. STexan
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    More specifically a "not adding DEF fluid as required" issue. Yet another "truck driver" out there with zero knowledge of the systems on modern trucks. If a trainer was ever involved they should be removed from the position, if no trainer was ever involved, how does one get a CDL with no knowledge of basic truck systems? SMH .... again
  7. zoekatya
    397
    99
    Mar 15, 2013
    Thanks for the helpful answers guys, not so much for others who called me a troll and were belittling.
    The only trolls are those on the questions for new drivers forum who contribute by putting others down.
    JReding Thanks this.
  8. mattbnr
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    I only said troll because I wouldn't expect anyone with at least a day of training to assume that the air tanks and the engine derating were somehow related.
    Def will derate, low coolant will shut it down.
    If I was you I'd ask for more training or your gonna have a very rough time out here.
  9. chris886
    chris886 Medium Load Member
    531
    286
    Aug 22, 2013
    Chicago, IL
    Power loss and regen are exhaust issues. Either no DEF or has to burn particles off of the exhaust filter. If it happens too often you may be idling too much or have a problem with your exhaust system. Has absolutely nothing to do with your brakes.
  10. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    I see proof of that every day I'm on the road.
  11. chris886
    531
    286
    Aug 22, 2013
    Chicago, IL
    Well you don't learn anything about DEF or regen to get your CDL. Private schools teach you to pass the DMV test and lot of small companies do not have trainers. I went local straight from school with no trainer, had me drive around for 15 minutes to make sure I could drive the truck, then here are the keys go to work. I had basic mechanical knowlage, but had to ask the other drivers a lot of questions. Never dealt with DEF or regen, the trucks in school were too old for that.
    I know 2 students from my school went OTR as a team together straight out of school with no further training, a couple others went solo OTR without a trainer.
