Need advice - safest mountain passes to drive out West
Discussion in 'Experienced Truckers' Advice' started by jennsunshine, Jul 4, 2018.
  1. jennsunshine
    jennsunshine Bobtail Member
    8
    6
    Jul 4, 2018
    Hi there,
    I have been doing some research and found this great forum. I figured the best, most common-sense advice on this topic would be from the most experienced truck drivers.
    I am making a cross-country move from Massachusetts to northwest Washington State, driving a fully-loaded 26 foot International One-Way Penske truck, towing a car carrier with a very small sub-compact car.
    Currently, I am outside of Scranton, PA, and have made it through the hills of the Poconos. Ended up having to switch out trucks, because the original truck we got could barely make it to 30mph with my foot to the floor. Turns out it probably had a blown transmission or exhaust manifold and is going to the graveyard. I’m very grateful hubby and I are with a friend, and discovered the problem now, rather than further west on our trip. It appears the original shop may have known it had problems, or didn’t do their due diligence inspecting the truck.
    Anyhow, we are going to continue on within the next 24 hours in a much better truck that has been thoroughly inspected. I can already feel the difference.
    We are plotting out our trip from here. We will most likely take I-90 and some of I-80 to our destination. I have been given a tutorial about safety guidelines, downshifting, etc...to the letter. Our whole life is in this truck.
    Our biggest concern is the mountain passes we encounter from Montana, Idaho and Washington. What are their names? Are there any with difficult switchbacks, curves or hairpin turns? The fewer mountain passes the better. I have driven over the passes before, in the late summer/early fall in a passenger car, so not totally unfamiliar.
    I am also being mindful of load shifting in the truck. I am pretty sure the packers evenly distributed the weight, although I know some may be closer to the back (lots of family paintings/artwork). Will this be an issue?
    Given all of this, would I-80 be better, to 84 in Oregon, and then up through the Tri-cities in Washington? We did this on the trip to Mass. 3 years ago. I would love to bypass the Seattle traffic as much as possible, as we are heading north of there.
    Anyhow, any and all sage advice is most appreciated.
    Thanks in advance.
    Jenn
  3. LoneCowboy
    LoneCowboy Road Train Member
    1,466
    3,600
    Oct 6, 2009
    Colorado
    i-90
    gear down going downhill, stay off the brakes, use the engine to keep you slowed
    follow the signs
    it's an interstate, you'll be fine.
    okiedokie and stwik Thank this.
  4. Judge
    84,390
    Mountainous driving isn’t that hard, if you go slow enough, signs will be posted, do not hit brakes then slow and release.
    Hold steady pressure, if you go to slowing to much let up off pedal some, but not all the way, the brakes get hot when overusing/getting air to them on the press and release methods, 90s the longest interstate in the US, but not to bad, remember, you can go to slow down a mountain several times, but only to fast once
    WiggleWagon and jennsunshine Thank this.
  5. Gumper
    Gumper Road Train Member
    1,532
    3,370
    Jan 7, 2018
    Butte, MT
    The interstate passes from western Montana to western Washington are no big deal this time of year. The four in my area I can think of are Homestake pass between Whitehall, MT, and Butte, MT. Then there’s Lookout Pass going from MT into ID. Fourth of July pass before you get to Coeur d’Alene which is significant in the winter, but hardly noticeable now. Then finally Snoqualmie into Seattle which is scenic, but not treacherous. Keep it about 45mph coming down the 6% hills, and you’ll be fine.
  6. IluvCATS
    IluvCATS Road Train Member
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    It’s gonna be a cakewalk. I-90 is beautiful once you enter Montana. Idaho on the 90 is cool. Yes, there are grades and you will be going slow up hill. You should watch your speed downhill. Snoqualmie Pass in Washington is your last one and then you’ll get stuck in traffic. Good luck.
    BUMBACLADWAR Thanks this.
  7. BIF MALIBU
    BIF MALIBU Heavy Load Member
    727
    420
    May 21, 2010
    lake cushman wa
    you can get off I 90 at ellensburg wa and go on state route 97 to sr 2 to Everett wa and miss Seattle
    your interstates are standard except the steepness of the mountain passes
    I have driven north of 90 on 97 and 2 for decades in heavy semi trucks
    this time of year there are many tourists in RV s and motorcycles out there and much scenery
    jennsunshine and IluvCATS Thank this.
  8. IluvCATS
    4,091
    8,976
    Dec 1, 2014
    Seattle, WA
    I’m a Seattlite and I just learned something new. I routinely go to Marysville to park my truck so that route would help me. Thanks for that!
  9. BIF MALIBU
    727
    420
    May 21, 2010
    lake cushman wa
    it's tough in the winter sitting atop Steven's looking at the icy 6% long downgrade
    IluvCATS Thanks this.
  10. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    is there such a thing as a safe mountain pass to descend? However traveling via the I - 90 , I -94 would be less mountainous till you hit MT, ID and WA can't avoid them mountains then if your still wanting to get into Washington.
  11. jennsunshine
    8
    6
    Jul 4, 2018
    Thank you all for the great advice. It has boosted my confidence. I am going to follow your advice with regard to speed and braking. I also figure if I could make it up and down some of these grades here on 84 going into Scranton with a piece of ####e truck with almost no transmission and a bent axle, I can get us over those mountain passes in a much better truck. Steady as she goes.
