need advice on fuel antigel and air lines antifreeze
Discussion in 'Trucks [ Eighteen Wheelers ]' started by trucker2009, Sep 30, 2009.
  1. trucker2009
    trucker2009 Bobtail Member
    10
    Sep 18, 2009
    hi All
    need advice again
    want to stack some for winter
    want to know witch product would be best for my volvo vn670 d12
    need diesel anti gel
    and air line antifreeze
    las winter was problem finding those products in truck stops
    now i want to buy and stack for winter
    tanks for any comment or suggestion .
  3. FYDA FREIGHTLINER CINCY
    FYDA FREIGHTLINER CINCY Light Load Member
    270
    131
    Apr 28, 2009
    Cincinnati, ohio
    we carry pen ray brand air line antifreeze and fuel treatment. and always have some in stock...
  4. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    A couple of bottles of airline antifreeze is all you will need. I properly serviced air dryer and air system should handle all your issues without using airline antifreeze...not to mention airline antifreeze is not recommended on almost all the modern air systems.
    As for the anti-gel...good tank heaters will help more than any fuel treat. But i have used Howes in the past, but it seemed to have less and less effect since the ULSD has been introduced. Powerserv is another decent one. This winter I will be trying out some of Schaeffers winter fuel treat.
    trucker2009 Thanks this.
  5. Jfaulk99
    Jfaulk99 Road Train Member
    2,914
    1,652
    May 16, 2009
    Couch
    Agreed, the only time I've seen a real need for it is if the air dryer isn't working right or hasn't been serviced properly. Or if you don't pull the same trailer all the time. Nothing like getting a trailer that someones truck filled with moisture on a cold day.
  6. PaulE
    PaulE Medium Load Member
    413
    145
    Jan 15, 2009
    Verona Wi
    Penray Winter power plus is excellent anti gel. have used it for over 10 yrs.has never failed me. not in t-stops. Freightliner dealers usually carry it and parts houses too.
    1 qt treats 250 gal about 9.00 ea. any FPPF products are also very good. Power service and Howes are expensive and dont work well with low sulfur fuels. junk in my opinion. airline antifreeze is not recommended in new systems. if you must use it then only a capfull. a pint should last many winters.
  7. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,538
    Jul 30, 2009
    Mapleton Depot,PA
    like others have said, if you air dryer system is working properly, there is no need for air line antifreeze.
    I've had good luck with both Power Service and Howe's. With 300 gal capacity, the Howe's is sometimes a better deal. But read the labels, if it is colder than 25 below it is colder than it says it will work and be guaranteed. I never had trouble with fuel until the past coupe of winters with the low and ultra low sulfur fuels. Now these are a necessity.
  8. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    For preventing your fuel from gelling, your best bet is mixing with #1.
    Power service and the others wont do dick with this ultra low sulpher juice today.
