Hey I am in need of a picture or something showing me what fuses go where an what they are for. I have a 2012 freightliner cascadia an it is missing the fuse panel cover for the fuse box under the hood that is bolted to the fire wall. Also would like to ask if anyone might know why the optimized idle wouldn't switch to the thermostat mode. It isn't shutting down the truck like it should.
Thank you for the help
Need a picture of fuse layout
Discussion in 'Freightliner Forum' started by Bigde88m, May 12, 2014.
Looks to me like a problem for Google.
I tried that couldn't find anything to help
Is this it?
Mikeeee -
Need to get the cover replaced anyway, water is not good mixed with electrical voltage. I wish we had optimized idle, it would be better than nothing, but I have never driven anything that had it where it wasn't disabled. Sorry I can't help with that.
Tail and marker lights are the last fuse, no.13 and it was 20 amps from the factory. The opti-idle was in the other box, the one in front of the one mounted vertical to the firewall, it may be a blown fuse for that as well. -
Page 202, almost at the end so scroll all the way down and come back. No picture but it lists their row and position.
http://www.freightlinertrucks.com/C...O-Manuals/english/cascadia_drivers_manual.pdf -
sam cab and chass fuse diagrams
