need 2 new bridgestone steering tires
Discussion in 'Questions From New Drivers' started by mert, Jul 19, 2013.
  1. mert
    mert Light Load Member
    90
    10
    Jul 13, 2013
    been serching ,no luck any1 has an idea where i can purchase 2 from
  3. abn75
    abn75 Light Load Member
    155
    92
    Jun 18, 2013
    Ummmmmm pretty much any ta/petro...heck any tire shop
    Sent from my SCH-I605 using Tapatalk 4 Beta
  4. mert
    90
    10
    Jul 13, 2013
    295 r75 22.5
  5. Wanderingaimlessly
    Wanderingaimlessly Medium Load Member
    445
    287
    Jun 18, 2013
    Los Angeles, Ca
  6. Boardhauler
    Boardhauler Road Train Member
    1,688
    3,200
    Dec 21, 2008
    Ballin' in it for Shakey
    have you thought of looking at a truck stop or a tire store?
  7. Rooster1291979
    Rooster1291979 Road Train Member
    1,308
    1,751
    Sep 4, 2012
    NOLA
    Where have you been searching? Walmart?
  8. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    should be common? if your trying to match the exact tread pattern or model that is currently on your truck you may have issues as tire manufactures can and will change tire designs and discontinue models ect on a regular basis. but as long as you change both it should be non issue to go with something slightly different than what you currently have.
  9. mert
    90
    10
    Jul 13, 2013
    285 r 75 22.5 isnot that frequent , i look it up on bridgestone website, and every1 is saying that is best to have all around the same size!!! but the sales man that one sale me some aeolas is telling me the the 295/r 75 22.5 is basically the same thing
  10. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Oh boy...........
  11. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,958
    Jan 18, 2011
    I believe the OP is talking about the difference between 22.5 low pros and standard--a 22.5 standard is the same size as a 24.5 low pro but on a 22 rim---BIT I see no problem w/runnin 22.5 standard on steer w/22.5 low pro rest of way around--lots do it with 24--low pros on trk/trl tall on steers--kinda of an ol skool less heat on steer tire reasoning--not sure it really matters
    So if this IS the ???? and form the OP wordin Im still not sure--BUT--since you have 22 rims--if you are havin trouble findin 22 standards--you can go lo pro w/same rims
