NC CDL Permit
Discussion in 'Questions From New Drivers' started by localguy65, Jul 25, 2018.
  1. localguy65
    localguy65 Light Load Member
    206
    95
    Oct 8, 2012
    I just went to the DMV to get my CDL permit and after passing the General Knowledge Test the attendant tells me I have to take and pass the air brake and combination vehicle tests to receive my permit...
    Is this true? I know combination is an endorsement. Not sure about the air brakes.
    I tried calling the NC DOT office but it was too late in the day.
    Thank you.
  3. Knoff1
    Knoff1 Bobtail Member
    40
    21
    Jan 11, 2014
    Yes, you need air brake
    localguy65 Thanks this.
  4. kemosabi49
    10,435
    44,383
    Jan 13, 2013
    SW Arkansas
    You need combination if you are going to pull a trailer too.
  5. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    to get a full Class A , CDL permit you need..
    1) general knowledge
    2) air brakes
    3) Combination vehicles
    you can get your hazmat, doubles/triples/tanker, at a later time.
    tscottme and localguy65 Thank this.
  6. localguy65
    206
    95
    Oct 8, 2012
    Thank you.
    I had no idea about the Air brakes and combination vehicle. Just missed this info somewhere.
    Studying now for the other 2 tests.
    buddyd157 Thanks this.
  7. ncmickey
    ncmickey Road Train Member
    3,820
    7,106
    Jun 21, 2013
    Durham NC
    Yea... you have to take all 3.
    One thing to remember... if you don’t know an answer hit SKIP. You have to answer a certain number right to pass the test. Once you hit that number, the test stops and you passed. So if you don’t know an answer hit skip and hopefully you will pass before that question comes back around!!
    localguy65 and John A. Thank this.
  8. tscottme
    tscottme Road Train Member
    What the DMV person told you is correct, assuming you are trying to eventually drive an 18-wheeler.
  9. localguy65
    206
    95
    Oct 8, 2012
    Yes, I am.
  10. kemosabi49
    10,435
    44,383
    Jan 13, 2013
    SW Arkansas
    The tests are not hard. You should consider taking the tanker and double/triples tests at the same time. They aren't hard either and even if you don't plan on pulling them the more endorsements you have the more marketable you make yourself. And there are practice tests here on TTR that will help you too. Good luck.
    buddyd157 and localguy65 Thank this.
