Narrowing down trailer light problem
Discussion in 'Ask An Owner Operator' started by SteveScott, Jan 5, 2020.
  1. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    So I have a year old Utility Reefer trailer that has some problems with the trailer lights. I noticed on my right turn signal I was getting a fast blink like a bulb was burned out, but when I'd do a pre and post trip everything was working. So yesterday I get back from a week on the road and parked in my yard. I was getting the fast blink while parked and decided to check the lights again. I walk to the rear of the trailer and my upper marker lights and the three lower right side parking/brake/signal lights are all dimmer than the rest of the lights. Working, but dimmer. So I have a short somewhere. Picked up a new pigtail, hooked it up and no change. Pulled the cover plate off of the junction box that the pigtail plugs into on the trailer and found a couple loose nuts on the wire holders. Tightend them all down good, and pushed the plate back into the box and the lights still do the same thing.
    So I have a wire that's grounding out somewhere. Anybody run into this before on Utility trailers? I hate to lose a day or two taking 50 miles to a dealer, but I can't run it like this.
  3. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    It sounds more like you have a bad ground somewhere.
    Dino soar, npok, lester and 3 others Thank this.
  4. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    you have a flaky ground, start theres junction box where it all comes together, thats the place to start
    Tall Mike Thanks this.
  5. SteveScott
    4,897
    16,806
    Nov 10, 2015
    Yeah I'm figuring a ground as well. I found it odd that where the plug plate fits into the junction box, all of the wires get shoved in there and could easily ground out on the side of the junction box. Seems like there would be some kind of cover to insulate them from rubbing the sides of the box.
  6. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Wrap electric tape or a 2" wide vinyl tape around the nose pigtail receptacle. This will help prevent insulation getting rubbed and wires getting pinched when you install.
    It does sound like a ground. It also could be a bad light.
    Good luck
    SteveScott Thanks this.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Get a rubber hamer and tap on lights with everything on and watch for changes in bulb brightness, you may find a bad shorted out china made light that was replaced on road one night?
  8. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Pull all the lights out from the right rear housing, you may find a bad wire in that region.
    I pulled a Wilson grain trailer, it was a real mess in there.
    Recently with my Doepker trailer I had a short, blew the fuse, in my clearance lights, turned out to be in the license plate light socket.
    Your problem will be where ever it is that the marker lights and the right tail lights all meet up.
  9. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Yea you would think so, but not. Very surprising that more trailers do not burn to the ground. Clean everything, a good electrical contact cleaner will help if its colorful, and things are growing, make sure the ground lug is clean, sand or wire brush. Good luck had to go in there plenty of times, never fun.
  10. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,079
    Sep 24, 2019
    Raleigh, NC
    Pigtail box
    Belly lines
    behind the left side brake lights.
    I've found an ABS light that was grounding out where the wires came out of the box behind the brake lights. Some times it can be the most minute thing that causes hours of grief.
    feldsforever Thanks this.
  11. Powder Joints
    7,506
    7,414
    Sep 25, 2007
    Rosamond, SoCal
    Glad you found it.
