N14 Rattle front drive
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Wrench_Shaker, May 16, 2017.
  1. Wrench_Shaker
    Wrench_Shaker Bobtail Member
    36
    11
    Feb 4, 2017
    I have N14 that rattles rymthic when the AC is turned on ac clutch engaged. It goes away when off or when the AC is on but fan is clutch is engaged.
    Worn accessory drive? bad pump?...ac works good. fan works good. sounds like it's in the drive
  3. AModelCat
    154,242
    Does it almost sound like the engine's labouring a bit when it happens?
  4. Wrench_Shaker
    36
    11
    Feb 4, 2017
    No i would say it just start to rumble....just like a rawww....rawww.....rawww.....then fan kicks on and goes right away.
  5. AModelCat
    154,242
    That kind of sounds like what a buddy of mine's N14 is doing. I never got to dig into it because he was busy. Would be curious if his has the same issue.
    Intothesunset Thanks this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Same basic set up as the NTC. Some of those sounded like they were grinding rocks. Saw some people through a lot of money at them and never make it go away. If the air compressor is not timed properly can cause and or exagerate this. If the accessory drive is not worn I would just run it. Wonder if that can be excessive gear backlash. You only hear it when the air compressor is pumping and or the a/c is on. Both units load and release the accessory drive. When the fan comes on it provides constant load to the drive and the noise stops. Thats my story.
  7. LoJackDatHo
    LoJackDatHo Medium Load Member
    446
    752
    Jan 26, 2017
    Check and make sure all bolts that attach the fan blade are there and tight. Then check belt tension. If accessory drive was bad, your air compressor and fuel pump wouldn't be working. If the accessory drive seal is out you would have oil slung all over. And if that seal is out, chances are you need a new front cover because the brass bushing is coming out, and they are pressed in the front cover. No fixing that bc once they move, it shuts off the oil galley. If you do need a front cover, 4 states in Joplin has aftermarket for $300. They are $1200-$1500 at cummins. I know, bc I put one in within the last 6 months.
    Sounds to me like fan could be loose or warped a little, belts could be too loose or too tight, ac compressor could be going bad, look for metal shavings around it.
    Intothesunset, mlefler and BoxCarKidd Thank this.
  8. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    I have heard a lot of N14 engines rumble like this when the A/C is on. The higher the pressure goes the more of a grumble it makes. I always contributed it to the weak A/C compressor mounts that a N-14 has.
  9. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    I would argue some of that but the belt is a very good point. Especially if it is made with notches in it. I have seen some of those make a lot of noise and they were not loose.
  10. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    If the fan is tight, check the fan clutch. The old air apply Hortons would wear the spline out on the center hub and let the fan move back and forth making a nasty rattling noise. Put air to it to engage the clutch and give the fan a good tug each way. If the fan moves back and forth a bit without the pulley moving (and the fan bolts are tight), the center hub splines are worn out.
    You can see the splines that I talking about in this pic:
    http://kitmasters.com/productimages/7500hp.jpg
  11. LoJackDatHo
    446
    752
    Jan 26, 2017
    Kit master is the way to go if replacing fan clutch. I think it's a much better system. That's what I replaced mine with, very happy and easy to do yourself. Good post GrapeApe
    HopeOverMope and Intothesunset Thank this.
