Hello all, I removed the Oil pump to change the gasket, and the small litle hose 1/4in that goes from the pump into the Cam follower, split in half, can I custom make one at a hydraulic shop or is it specially made that I have to replace OEM?
The reason I ask is Freightliner does not have it in stock and they want a 100 dollars for it its a 6in braided steel hose, with 1/8ntp fittings on each end. but 100 dollars....
Thoughts opinions please?
Thank you
N14 oil pump hose going into cam folower?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by thesvg, Jun 13, 2011.
