N14 Cummins Mechanical or Electronic??
Discussion in 'Trucks [ Eighteen Wheelers ]' started by hawkjr, Jan 6, 2013.
  1. hawkjr
    hawkjr Road Train Member
    1,652
    638
    Feb 28, 2010
    Virginia
    I'm looking at an truck, 92 Peterbilt with an N14 Cummins. I'm planning on trying to lease to Landstar but recently they just converted new hires onto Electronic logs meaning you have to have an Electronic motor (so what i was told) to lease on. I know they made N14's up to the early 2000's so I'm not sure if it's one of the early Mechanical motors or the other. Really like this Truck, actually if i can't lease it on to Landstar I might just go out on my own but i prefer to try Landstar first...
  3. JarradS
    JarradS Light Load Member
    132
    35
    Sep 18, 2012
    Perth, Western Australia
    Pretty sure n14 is electronic. NTC is the mechanical predecessor IIRC
  4. durallymax
    durallymax Medium Load Member
    318
    97
    Jan 30, 2011
    Picture of the driversside of the motor will tell.
    Afaik all N14 on road engines were electronic. They should be painted black. Isx should be red and older mechanical motors tan.
    Sent from my SCH-R530U using Tapatalk 2
  5. CatPowerC15
    CatPowerC15 Medium Load Member
    347
    90
    Feb 18, 2010
    Siler City, NC
    The first N14's were mechanical step timed....
  6. durallymax
    318
    97
    Jan 30, 2011
    The celect was their first electronic system correct ?
  7. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    the first N 14 were mechanical injected, a 1992 could easily be mechanical, but you can find some untill 1996, I love those N14, they are powerful and very reliable as well as good on fuel.
    I knew a guy in California that had two 1991 mechanical N14 500 hp, those are the only ones I have ever seen.
  8. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    I've seen mechanical ones before, as well. Did you see an ECM anywhere when you opened up the hood? Or did you notice a bus port anywhere in the driver's compartment?
  9. jcald
    jcald Bobtail Member
    6
    Aug 9, 2012
    Landstar or not If the Truck is in Pretty Good shape Id Go with the N14 for reliability. There easy to tell what you have in Mechanical or Electronic Motor Just by looking at Motor and Wiring Harness. The Old NTC's aka Big Cam Motor, and KTA's are all mechanical.
  10. hawkjr
    1,652
    638
    Feb 28, 2010
    Virginia
    Truck had new injectors but he didn't have any paper work on it, 1.3 million on the truck... cosmetically the truck looks good
