N14 Cummins hard start
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Kenllah, May 1, 2020.
  1. Kenllah
    Kenllah Light Load Member
    226
    113
    Nov 17, 2017
    Had an issue with my n14 celect plus taking 10 seconds of cranking to start. I checked the fuel system for leaks and it was solid. Checked fuel shut off and it had power 12v. Put pressure gauges on the the test ports and checked cranking pressure. Truck always fired once fuel pressure reached 25psi or above was just taking a while to get there. So pressurized the fuel tanks and tried to start it but still a hard start. What finally worked was supplying fuel at 25psi to the filter housing . The darn thing fired in 2 seconds or less every time. Hooked everything back up normal and it fired right up. Waited overnight and it fired right up. This may not be a solution for you but it's free to try to see if it works on your n14. There are several other possibilities for hard starts on n14s so it's best to go with the free stuff before just swapping parts.
  3. DUNE-T
    DUNE-T Road Train Member
    6,874
    16,589
    May 10, 2015
    Detroit, MI
    My two N14's usually have a hard start when I use red Baldwin fuel filters. What filter do you have?
  4. Shawn2130
    Shawn2130 Heavy Load Member
    894
    1,892
    Sep 20, 2015
    Ontario
    I have noticed that certain fuel filters can cause issues.
    The Cat C15 I use took 45 seconds to get pressure on the gauge. Truck still fired right away but 45 seconds for the needle to get up.
    Threw the Donaldson filters out, installed Cat filters.
    Fuel pressure went up right away while cranking before the engine fired.
    Much better.
  5. Kenllah
    226
    113
    Nov 17, 2017
    Fs 1000
    jsnell Thanks this.
  6. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    There's a quad ring with replacement fuel filter that most of the time is not installed. Which creates this problem.
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Fuel check valve at the ECM sticks, lets fuel drain back, hard start. Common on N-14's do a search.
    wore out and Shawn2130 Thank this.
  8. Eckman deisel repair
    Eckman deisel repair Bobtail Member
    12
    7
    May 1, 2020
    There is a check valve on the left side of the cooling plate which the computer is mounted too. Its in the fitting. You can easily take the line off and pull the fitting apart to check if anything is keeping it held open when not running. Sometimes but not always there is a check valve on the fuel pump at the back on top. If so you have to pull off the electric solenoid off the pump to get it out.
  9. Final Drive
    1,573
    2,505
    Jan 21, 2015
    He dint say after sitting for awhile..
  10. Kenllah
    226
    113
    Nov 17, 2017
    Generally if a check valve is bad it will start and run then stop. Then crank some more and run. I've had that problem before. Current crank time is appx 1.9 seconds. Granted my 3406e cranks about half a crank and she's running...
  11. DougA
    1,429
    8,892
    Dec 16, 2013
    Not on the N-14 check valve. I owned my N-14 500 20 years, and in that time replaced it twice. It's a simple ball and spring, when the fuel pump runs it flows. When you shut the engine off, the ball doesn't seat, from either worn spring, or tiny chip on plastic ball, dirt,etc. Fuel drains back, you have to crank it to get the fuel back up. Simple 10 minute fix. Very common problem on the N-14
    wore out Thanks this.
