N-14 Cummins SID 254 FMI 8
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Smellfunny, Sep 12, 2013.
  1. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    N-14 Cummins SID 254 FMI 8 Fuel Pump Control Module
    1999 N-14 Celect Plus. Engine is cutting out a little at acceleration. This is an active code.
    Any thoughts?
    It also has a SID 23 FMI 5 which shows on Prolink as Rack Actuator. Not even sure why that would come up on an N-14.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    I don't see anything with that code. There are a couple with PID 254, FMI 12 which are internal faults to the ECM. Main cause is poor grounds, moisture or a faulty engine position sensor.
    Smellfunny Thanks this.
  4. Smellfunny
    1,445
    967
    Jan 28, 2012
    South Carolina
    Yeah I told the customer that most the time a 254 is a ECM or wiring harness or both issue. The SID 254 FMI 8 number I only see in a fault code book and can find no further information. That other code for rack code makes no sense at all. I might tell him to take it to someone that has cummins software.
    Thanks Heavy.
    Heavyd Thanks this.
