My truck is leaking oil in two places on the right side of the engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by carson_77, Dec 6, 2022.
  1. carson_77
    carson_77 Bobtail Member
    25
    4
    Feb 21, 2022
    I would like to ask you a few questions. There are two places on the right side of my car engine that are leaking oil. What are the parts of these two places that are leaking oil called? Can I replace it myself after I go to the store or do I need a mechanic? If a mechanic is needed, how much would it cost?
  3. Raffito
    Raffito Light Load Member
    84
    53
    Aug 25, 2019
    Ingram, TX
    The first one is the turbo oil drain tube gasket and the second one is the engine breathe tube O' ring.
    You can buy the gasket and replace it. And you may have to replace the breather tube. if you can find an o'ring to fit you can just replace it. Get some brake kleen to clean the engine.
  4. ducnut
    ducnut Road Train Member
    2,429
    7,214
    Dec 31, 2010
    SPI
    ^^^ Nailed it!
  5. carson_77
    25
    4
    Feb 21, 2022
    Thank you very much, my friend! Life is more wonderful with you!
  6. mjd4277
    mjd4277 Road Train Member
    13,886
    41,493
    Oct 4, 2015
    Fitchburg,MA
    What kind of vehicle and engine is it?
  7. carson_77
    25
    4
    Feb 21, 2022
    2016 freightliner Cascadia, engine is DD15
    mjd4277 Thanks this.
  8. mjd4277
    13,886
    41,493
    Oct 4, 2015
    Fitchburg,MA
    Cool. Also,be wary of fuel leaks around the injectors and/or the fuel rail.
  9. Lazer
    Lazer Road Train Member
    1,728
    2,725
    Jan 22, 2017
    Does it leak enough that it drips onto the ground?, if not I wouldn’t get to excited about it.
  10. carson_77
    25
    4
    Feb 21, 2022
    Not yet, these two places are just oozing at the moment!
