My seat won't hold air
Discussion in 'Experienced Truckers' Advice' started by Flatbedder73, Aug 21, 2013.
  1. Flatbedder73
    Flatbedder73 Medium Load Member
    464
    354
    Dec 30, 2012
    Langhorne, PA
    Im sure the subject line will lure some good jokes, but anyway.....
    I hit the switch to air up my seat, it raises normally, then slowly loses the air over a minute or two. Of course my first thought is that there is a leak to find, but was wondering if there is anything else I could check? I looked all around under the seat, and couldnt see anything abnormal or hear any leaks. Please help!
    Alexp2686 Thanks this.
  3. Lilbit
    Lilbit Road Train Member
    16,583
    12,232
    Aug 4, 2008
    Let me check my logbook
    Check the line and fittings. Make sure nothing is pinching the line.
    Flatbedder73 Thanks this.
  4. One_tooth_wonder
    One_tooth_wonder Light Load Member
    172
    213
    Aug 7, 2008
    Cleveland, TX
    Mine did the same thing, and it was the fitting where the hose went into the airbag. It took different amounts of time to deflate, depending on how much bouncing was going on.
    Shop never would fix it, and I got tired of hitting the air button a couple hundred times a day, so I tried to just flat out rip the line out of the bag, and the leak stopped.
  5. Flatbedder73
    464
    354
    Dec 30, 2012
    Langhorne, PA
    ok...will look where the bag is.....thanks!
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,647
    15,955
    Jan 18, 2011
    What kind of truck?
  7. Lonesome
    Lonesome Mr. Sarcasm
    10,942
    22,206
    Dec 15, 2007
    Northern Indiana
    I had a KW that did that. Air line was chafed from rubbing against the seat frame.
  8. Flatbedder73
    464
    354
    Dec 30, 2012
    Langhorne, PA
    Its an 05 Columbia, but its not the original seat....owner just replaced it last year.
  9. ‘Olhand
    6,647
    15,955
    Jan 18, 2011
    Really just asking to be a smart ###--but since u said Columbia--its obvious it wants to be aPete:D
    Couldn't help it
    Lilbit and rockee Thank this.
  10. TrukTuff
    TrukTuff Light Load Member
    167
    113
    Aug 22, 2013
    Anaheim, CA.
    I have a 2012 Freightliner Cascadia, and my seat sometimes does the same thing. What I have found is that the switch that I push to raise or lower my seat sticks occasionally. When I get up and out of the truck, I can hear the air leaking out and if I stand and watch it, I can see the seat go to the lowest point. I just tap the switch until it stops leaking air. But I suppose I could just clean the switch and see if it keeps it from sticking too. Hope this info helps.
  11. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    blow the seat up to normal height with you in the seat. about the truck if so you can hear, get out and put your head under the seat, if you still don't hear an air leak, spray all fittings, the airline, and air bag with a soap and water solution, if you still don't see or here the leak, it's most likely the check valve, unfortunately that's usually built into the switch
